Elephant Repository
 1-10  …  31-50  51-70  71-90  91-110  111-130  …  491-503
Ok I have nailed it! :)
All points are "Long"
Ok all is mastered! (my headache also! :)
And of course that change if you modify the Points modes itselves! :)
So 2 (modes start pts) * 2 (modes end pts) * 5 (modes lines) = 20 possible combinaisons of modes! (for the moment)
here only the "Pts" so 4 variants with "Long Lines"
EDITED: 3 Sep 2019 by PILOU
Added Node Line (English) + paradigmatic Modes :)
http://moiscript.weebly.com/curves.html
Added Node Circle (English)
Added Node Rectangle (English)
I have some troubles with the Nodes Curve, Polyline! :)
Added Arc Center (English)
Added Circle Dia (English)
Curiously there is not Input inside the Info Panel!
EDITED: 4 Sep 2019 by PILOU
Added Circle 3 Pts (English) Input datas only by Nodes ! Not Possible by Info Panel !
Added Ellipse Center (English)
Added Ellipse 3 Pts (English)
Maybe a little glitch on the "Z" Point drawing? (not on the ellipse perimeter! )
I am blocked with the Nodes Curves & Polylines for Input datas ! ???
If you have some lights about that! :)
9476.86 In reply to 9476.85
Look at the curves.js file for the geometry definitions.
// Curve
function Curve()
this.addInput("In","pointarray");
this.properties = { mode:["Curve", "Curve", "Interpcurve"], closed:["No", "No", "Yes"]};
// Polyline
function Polyline()
this.properties = {closed:["No", "No", "Yes"]};
Wayne
EDITED: 4 Sep 2019 by WAYNEHILL5202
9476.87 In reply to 9476.85
The 3 colours of wires and connectors (inputs & outputs) represents the 3 data types:
GREEN = number data (numbers or numArrays)
PINK = point data (points or pointArrays)
YELLOW = objects (curves, surfaces or bReps)
So Curve & polyline nodes inputs are PINK and hence point arrays (minimum length of 2)
Hope this makes sense.
PS Keep up the good work.
EDITED: 4 Sep 2019 by JFH
Yes I am totally agree with you but the problem is that i don't find the good "native" Nodes for that! :)
(simple way like that or more complex)
I must miss something trivial!
9476.89 In reply to 9476.81
So Green inputs may have default values in the info window(?) Pink pointarray inputs do not have such default values in the info window (?)
Also Vertikal should be changed to Vertical :-)
9476.90 In reply to 9476.89
Vertikal is Max ! ;)
<< Pink pointarray inputs : what is the name of this node (if it's a native one)
Polyline has no case for input list of something
Show messages:  1-10  11-30  31-50  51-70  71-90  91-110  111-130  131-150  …  491-503
