| Mode "Switch":A left click on the body of the node changes the input state to the opposite configuration.  The state is latched / fixed. (is semi-permanent).
 ---Pre-existing top input state becomes bottom input state.  And stays in that state until some other mouse action.
 ---Pre-existing bottom input state becomes top input state.  And stays in that state until some other mouse action.
 Mode "Button":
 A Left click and HOLD, changes from the top input state to the bottom input state.
 Upon release of the Left click Hold, the top input state is restored.  (not exactly a Toggle?)
 Mode Change in the info window:
 If mode is changed from Switch mode to Button mode:
 either   I.  A pre-existing top input state is preserved.
 or else II. A pre-existing bottom input state changes to top input state.  (Which is latched / fixed.)
 (So it is not possible to be in button mode and have click and Hold engaged, and be in the top input state.)
 (So many words to describe "simple" switch:-)
 (Toggle is a pretty good word.  Permanent is perhaps not so good a description.  I used semi-permanently, perhaps not so good either.  Latches is a pretty good word.)
 Latching a gate closed does not permanently close the gate.  But does close the gate until some other action occurs.
 latch, latching
 fasten (a door or gate) with a latch.
 "she latched the door carefully"
 synonyms:	fasten, secure, make fast, bar, bolt; More
 ELECTRONICS
 (of a device) become fixed in a particular state.
 Toggle indicates a change of state.
 verb
 1.
 COMPUTING
 switch from one effect, feature, or state to another by using a toggle.
 "the play/pause button toggles between those functions"
 The French words are up to you :-)
