| Hi Pilou,
 The Switch in switch mode maintains the connection between the input the internal wire is currently touching, and the output.
 Left mouse clicking the Switch body changes the connection to the other input.  After finishing the click, the connection with the other input is maintained,
 until another left mouse click is performed.
 When the Switch is in button mode, without being manipulated with the mouse, the connection is with the upper (top) input.
 Then, in button mode, holding down the left mouse "key button" on the switch icon body, causes the connection to change to the lower (bottom) input.
 When the user ceases to hold down the left mouse "key button" on the switch icon body, the connection reverts to the upper (top) input.
 Your dynamic picture should be redone, because you are failing to select the switch mode, and you are only showing the button mode function.
