Elephant Repository
 1-14  …  455-474  475-494  495-503
9476.495
I am trying to count the one's in the array is this possible ?
Barry
Message 9476.496 deleted 23 Jan 2022 by JFH
9476.497 In reply to 9476.495
Barry,
You could use Split Node to select only the ones
& then Length Node to give the quantity.
9476.498 In reply to 9476.497
Thanks James,
work great.
Barry
9476.499
Hello All,
It seems I cannot find "Clone ToPts" Where should I look for it?
9476.500 In reply to 9476.499
Hi Psygorn,
CloneToPts is in the points menu.
Wayne
Size: 63.9 KB, Downloaded: 61 times, Dimensions: 626x668px
9476.501 In reply to 9476.500
Hi wayne hill (WAYNEHILL5202),
Thank you so much.
9476.502
Hello James,
I tried to recreate what you have created here: https://www.instagram.com/p/CarUhPAPopQ/
(Explode Move)
I can see a much simpler shape on Moi3D view ports and it does no move! (it is not dynamic although I used Quartz node just like u used) my output says "12" not "320". What am I doing wrong?
Node file is attached.
9476.503 In reply to 9476.502
Psygorn
Yes the more objects elements, the slower the animation due the increased computational load;
so I sped up playback of output animation in post-production (iMovie).
Try these values in Basic/Quartz:
Start 0
End 5
Step 0.1
Mode Tic-tac
Have a great weekend
Show messages:  1-14  …  435-454  455-474  475-494  495-503
