Elephant Repository
 1-7  …  448-467  468-487  488-503
9476.488 In reply to 9476.486
Hi Psygorn.
Enter the numbers separated by commas, this will be the array later on.
The entry you see on the screenshot is formed when there are more than 16 digits in the input line, including commas and dots.
This is done intentionally so that the node is not stretched because of the large number of digits.
9476.489
I'm having a problem with the offset node flip option not working below 0.1 .
The offset both sides works perfectly at below 0.1 ?
I searched forum for solution but found nothing.
Any help appreciated.
Barry
EDITED: 20 Jan 2022 by BARRY-H
9476.490 In reply to 9476.489
Yes there is something wrong in the node Offset! :(
9476.491 In reply to 9476.489
Hi Barry.
There is a simple solution, look attached screenshots on them in the line 546 there is a value, it is circled, increase it as you need.
This will allow you to work with less indentation, but it will still stop.
Note: the line number may be different in your files because I changed my file.
Look from the line with "//mLoft2".
Size: 131.3 KB, Downloaded: 67 times, Dimensions: 1644x886px
Size: 126.3 KB, Downloaded: 65 times, Dimensions: 1670x886px
9476.492 In reply to 9476.491
Hi WN,
thanks I had already found that line and modified it but not being a coder wasn’t sure I was doing the right thing but it does work.
I increased it to 100.
Is this a pick point position for the offset to know which side to offset ?
Again thanks for having a look.
Barry
9476.493 In reply to 9476.487
Thank you, James.
9476.494 In reply to 9476.488
Thank you, WN.
9476.495
I am trying to count the one's in the array is this possible ?
Barry
Message 9476.496 deleted 23 Jan 2022 by JFH
9476.497 In reply to 9476.495
Barry,
You could use Split Node to select only the ones
& then Length Node to give the quantity.
9476.498 In reply to 9476.497
Thanks James,
work great.
Barry
9476.499
Hello All,
It seems I cannot find "Clone ToPts" Where should I look for it?
9476.500 In reply to 9476.499
Hi Psygorn,
CloneToPts is in the points menu.
Wayne
Size: 63.9 KB, Downloaded: 61 times, Dimensions: 626x668px
9476.501 In reply to 9476.500
Hi wayne hill (WAYNEHILL5202),
Thank you so much.
9476.502
Hello James,
I tried to recreate what you have created here: https://www.instagram.com/p/CarUhPAPopQ/
(Explode Move)
I can see a much simpler shape on Moi3D view ports and it does no move! (it is not dynamic although I used Quartz node just like u used) my output says "12" not "320". What am I doing wrong?
Node file is attached.
9476.503 In reply to 9476.502
Psygorn
Yes the more objects elements, the slower the animation due the increased computational load;
so I sped up playback of output animation in post-production (iMovie).
Try these values in Basic/Quartz:
Start 0
End 5
Step 0.1
Mode Tic-tac
Have a great weekend
Show messages:  1-7  …  428-447  448-467  468-487  488-503
