Elephant Repository
 1-10  …  431-450  451-470  471-490  491-503
9476.471 In reply to 9476.470
Barry,
That's odd!
If you look at attached image, you can see that the dimensions of generated voronoi are well over 100 units.
Did you shut down Moi3d.app & restart before reloading NOD file?
9476.472 In reply to 9476.461
And how did you do that?
9476.473 In reply to 9476.471
Hi James,
yes my mistake hadn't closed moi your new voronoi node works thank you.
Do you have the same issue with the randompts not updating in the panel ?
Many thanks
Barry
9476.474 In reply to 9476.473
Barry,
I'm not sure what you mean.
Hasn't the issue of unpatterned half torus been solved?
9476.475 In reply to 9476.466
Hello again James,
I'd be happy if you guide me here as well. :-)
Happy weekend :-)
9476.476 In reply to 9476.475
Psygorn,
Replace voronoi.js file in app support/Moi/nodeeditor/nodes/extensions/
with file attached.
EDITED: 19 Dec 2021 by JFH
9476.477 In reply to 9476.474
Hi James,
yes the torus node works perfectly.
My query is the randompts inputs do not update in the info panel but updates correctly in the model.
See photo.
Also could you upload the extendsrf nod please Wayne as removed it.
Again many thanks.
Barry
9476.478 In reply to 9476.474
Hi James .
I also show it that way, but it's easy to fix. The files are different, the difference is only two lines, attached a screenshot. Now everything works well.
EDITED: 19 Dec 2021 by WN
Size: 34.6 KB, Downloaded: 51 times, Dimensions: 1919x300px
9476.479 In reply to 9476.477
Barry,
Ahh yes, I've never notice the the info panel does not update properly.
This must be a glitch in the script.
9476.480 In reply to 9476.476
Hi James,
And thank you. it works fine.
9476.481 In reply to 9476.477
Hi Barry-H.
Now the data will be updated, I added the necessary lines in the script.
9476.482 In reply to 9476.481
Hi Wayne,
thanks works perfect.
Have a good Xmas
Barry
9476.483 In reply to 9476.472
<< How do you make that ?
@Psygorn
Just launch the James .nod voronoi
Copy / Move /Scale some times the result (half full / voronoi )
Then export as OBJ
and input by Drag and Drop files into the crazzy free SPline! :)
you can make UVs inside Spline
https://spline.design (better than SketchFab because you have a true real 360° on the 3 axes! )
some animations are started by click on the object! ;)
(background & Ground are Spline but of course all can be made inside MOI3D before OBJ exportation)
PS and of course the crazzy textures by the free online Vervette SandBox ! :) http://www.taron.de/Vervette/sandbox/
EDITED: 19 Dec 2021 by PILOU
9476.484 In reply to 9476.482
Hi Barry-H.
Wayne does write good scripts, I just added a few lines.
Perhaps this was done on purpose, when you turn off the input returns the default data.
9476.485 In reply to 9476.484
Hi WN
apologies for name mix up but thanks again for sorting the issue out.
Barry
9476.486
Hello all,
How could we have constant with Array input?
please take a look at James work here: https://www.instagram.com/p/CYv6vIlP0Zy/
I tried to reconstruct it but I get an Error!
Node file attached
9476.487 In reply to 9476.486
Psygorn
The constant node contains a 2 number array: 0,6.283 (0,2*PI)
See attached NOD file .
9476.488 In reply to 9476.486
Hi Psygorn.
Enter the numbers separated by commas, this will be the array later on.
The entry you see on the screenshot is formed when there are more than 16 digits in the input line, including commas and dots.
This is done intentionally so that the node is not stretched because of the large number of digits.
9476.489
I'm having a problem with the offset node flip option not working below 0.1 .
The offset both sides works perfectly at below 0.1 ?
I searched forum for solution but found nothing.
Any help appreciated.
Barry
EDITED: 20 Jan 2022 by BARRY-H
9476.490 In reply to 9476.489
Yes there is something wrong in the node Offset! :(
Show messages:  1-10  …  411-430  431-450  451-470  471-490  491-503
