Elephant Repository
 1-18  …  419-438  439-458  459-478  479-498  499-503
9476.459 In reply to 9476.457
Hi James,
I'm only getting half the torus with a voronoi pattern ?
Also I noticed that the inputs to the randompts node does not update in the panel in the nodeditor but does update the drawing.
Perhaps its my version of the nodeditor.
Anyway thanks for posting have a good Xmas.
Barry
9476.460 In reply to 9476.459
Hi Barry-H,
I noticed that too but I think with a little bit of tweaking u can have a torus voronoi-ed all over :-)
I have to confess I don't know about the nodes or how they work at the moment! I just hope this could be helpful.
Possibly James could provide a deeper explanation :-)
EDITED: 18 Dec 2021 by PILOU
9476.462 In reply to 9476.460
Hi Drillbit,
yes I had got a result also by tweaking the rectangle sizes.
Barry
9476.463 In reply to 9476.459
Barry / Psygorn,
I am unable to repeat the pattern on half issue that you have experienced.
Nevertheless I made a small change to NOD file scaling original rectangle
rather than generating a 2nd rectangle, though it is unlikely that this is the problem.
What is more likely is that the issue is copying of point field into 4 quadrants
prior to generating the voronoi pattern. This should be possible to do with a
single "MovePts" node but it fails to work, necessitating the use of 2 such nodes in series.
It would appear that this 2nd move (copying) is not registering for you.
I am not sure if the reason I have not experienced the same problem is due to the fact
that I am using beta version for Mac M1 processor.
There is one more thing I could try: converting points to point object and then copying them
into quadrants before reconverting back to point field. I imagine that this would radically
increase the computation load since new geometry would be generated with each "MovePts"
operation.
But first let me know if problem persists with this new NOD file
Have a great weekend
9476.464 In reply to 9476.463
Thank you James.
For what it is worth, my computer is still generating half of the torus with unperforated inner and outer skins.
9476.465 In reply to 9476.463
Thank you James,
However, as bemfarmer mentioned the issue still exists!
9476.466 In reply to 9476.463
Hello James,
I tried to recreate one of your works.
you can see it here: https://www.instagram.com/p/CCo6mQUJxkN/
But I ran into that problem.
you can see the Error here: https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.240
9476.467 In reply to 9476.465
Psygorn,
Try this version.
I have repeated original point field via math operation to x & y data.
It works for me...but then again so did my last NOD file.
I have been unable to reproduce the error that everyone else seems to have.
9476.468 In reply to 9476.467
Hi James,
still the same issue.
I think its the voronoi node I can only generate in a rectangle up to 100 x 100.
If I take your original nod and just adjust the Y constant from 200 down to 100 all works fine.
The photo shows the results when reducing the Y value.
Barry
EDITED: 18 Dec 2021 by BARRY-H
9476.469 In reply to 9476.468
Thanks Barry,
Actually that rings a bell.
Try replacing your voronoi.js file in extensions folder with the one attached.
It is possible that mine is an updated version
See how this works with my first version of NOD file
9476.470 In reply to 9476.469
Hi James,
no go with that voronoi node.
Your original nod file works by reducing the X & Y constants to X 35 Y 50 plus reducing the voronoi space to 0.5.
Barry
9476.471 In reply to 9476.470
Barry,
That's odd!
If you look at attached image, you can see that the dimensions of generated voronoi are well over 100 units.
Did you shut down Moi3d.app & restart before reloading NOD file?
9476.472 In reply to 9476.461
And how did you do that?
9476.473 In reply to 9476.471
Hi James,
yes my mistake hadn't closed moi your new voronoi node works thank you.
Do you have the same issue with the randompts not updating in the panel ?
Many thanks
Barry
9476.474 In reply to 9476.473
Barry,
I'm not sure what you mean.
Hasn't the issue of unpatterned half torus been solved?
9476.475 In reply to 9476.466
Hello again James,
I'd be happy if you guide me here as well. :-)
Happy weekend :-)
9476.476 In reply to 9476.475
Psygorn,
Replace voronoi.js file in app support/Moi/nodeeditor/nodes/extensions/
with file attached.
EDITED: 19 Dec 2021 by JFH
9476.477 In reply to 9476.474
Hi James,
yes the torus node works perfectly.
My query is the randompts inputs do not update in the info panel but updates correctly in the model.
See photo.
Also could you upload the extendsrf nod please Wayne as removed it.
Again many thanks.
Barry
9476.478 In reply to 9476.474
Hi James .
I also show it that way, but it's easy to fix. The files are different, the difference is only two lines, attached a screenshot. Now everything works well.
EDITED: 19 Dec 2021 by WN
Size: 34.6 KB, Downloaded: 51 times, Dimensions: 1919x300px
Show messages:  1-18  …  399-418  419-438  439-458  459-478  479-498  499-503
