Elephant Repository
 1-4  …  405-424  425-444  445-464  465-484  485-503
9476.445
Hello all,
I am useing MOI3D V4, and Nodeeditor 1.1jms
if you take a look at the link below u can see James had created a Voronoi cylindrical shape.
https://www.instagram.com/p/CK8Qb6XsHOa/
However, when I tried to recreate it I could not find "Rectangle2", "idSelect" and "contact" as shown in the post above. ( I hope it is not hidden from my eyes!)
I need your help what should I use instead of those nodes in order to recreate what James had created?
9476.446 In reply to 9476.445
Hi Psygorn, to get the latest one posted by James, go to: https://moi3d.com/wiki/Nodeeditor and then the link for "Most recent version with new extensions collected by James here: " .
If the one there doesn't have it then you'll need to wait until James updates it with his newest nodes.
9476.447 In reply to 9476.446
Thank you for your reply,
this post of James: https://www.instagram.com/p/CK8Qb6XsHOa/ was made 44 weeks ago; we can say roughly 11 months ago, which means January 2021.
I took nodeeditor which I use currently from here: http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10 ( which goes back to September 14th, 2020)
So, I believe James had access to the latest version when he made the post on Instagram.
Maybe I cannot use nodeeditor latest version (AKA nodeeditor 1.1 jms) properly! I tried to find some nodes but I was not successful.
For example I cannot find Rectangle 2
or idScale.
Again I have to admit maybe it is my fault and I am not looking in the right place for it. but also it could be that James had used another version of nodeeditor when he made that post on Instagram.
-Psygorn(Drillbit)
9476.448 In reply to 9476.447
Hi Psygorn,
After much looking, rectangle2 node was located here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1710
There are 4 "new" nodes in file >>>>>>>>>>>>>>"shapes.zip".<<<<<<<<<<<<<<<
(Wayne's shape nodes???)
Unzip the file, and copy the 4 .js files to your %AppData% folder.
For Windows 10, ...AppData\Roaming\nodeeditor\nodes\extensions.
I am so rusty at nodeeditor, it may be that these 4 nodes are not yet integrated into nodeeditor menus. Not sure.
They are coded to hook themselves into the Curves2 menu...
(Circle2, Star2, Polygon2, and Rectangle2)
EDITED: 12 Dec 2021 by BEMFARMER
9476.449 In reply to 9476.448
Hello Brian,
Thank you for your reply, I found those nodes u mentioned. however, I did not find idSelect! and I did not achieve the same results as James did!
Here is what James has achieved: https://www.instagram.com/p/CK8Qb6XsHOa/
and I have attached the Node file to this reply, please take a look at it. ( I know you are rusty but I believe you might be able to help me to recreate what James had recreated)
9476.450 In reply to 9476.449
Hi Psygorn.
Something like this.
9476.451 In reply to 9476.450
Hi WN,
Yes! u are a wizard!
Thank you!
(Gods of nodeEditor heard my call :-)
9476.452 In reply to 9476.450
By the way, I have a question,
In James Instagram post, it seems the generated mesh does not have a seem line, is it because it is rendered? or is it because of his node?
James post: https://www.instagram.com/p/CK8Qb6XsHOa/
9476.453 In reply to 9476.452
Psygorn,
Yes the .nod file generated a seamless mesh.
Unfortunately I long ago deleted the original file,
but I will rebuild and post over the weekend.
EDITED: 16 Dec 2021 by JFH
9476.454 In reply to 9476.453
Thank you James :-)
And I wonder could that pattern be applied to a torus?
And how can I get a decent understanding of nodes? from where should I start? to me it looks like dark magic! :-)
9476.455 In reply to 9476.454
Since a torus is a rectangle plane that is rolled up, then curled around, it should be easy to make up a voronoi torus. See previous hex patterns on torus, nodes.
9476.456 In reply to 9476.454
<< from where should I start?
Make very small ones, reload yet made, and training 26 h / 24 h ! :)
And of course https://moiscript.weebly.com/biblio-elephant.html
Bon courage!
PS It's more easy to use a Node(s) than create it!
This one by r2d3 is a true gem: you can animate anything along any path! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.878
EDITED: 17 Dec 2021 by PILOU
9476.457 In reply to 9476.454
Psygorn,
As Brian says it is easy to flow a pattern to torus since it homologous to a rectangle.
The trick however to make the voronoi pattern seamless over the surface, is to repeat
the random point field offset in both dimensions, generating the pattern and intersecting with
the original frame prior to applying flow.
.nod file attached.
EDITED: 17 Dec 2021 by JFH
9476.458 In reply to 9476.457
Thank you James,
9476.459 In reply to 9476.457
Hi James,
I'm only getting half the torus with a voronoi pattern ?
Also I noticed that the inputs to the randompts node does not update in the panel in the nodeditor but does update the drawing.
Perhaps its my version of the nodeditor.
Anyway thanks for posting have a good Xmas.
Barry
9476.460 In reply to 9476.459
Hi Barry-H,
I noticed that too but I think with a little bit of tweaking u can have a torus voronoi-ed all over :-)
I have to confess I don't know about the nodes or how they work at the moment! I just hope this could be helpful.
Possibly James could provide a deeper explanation :-)
EDITED: 18 Dec 2021 by PILOU
9476.462 In reply to 9476.460
Hi Drillbit,
yes I had got a result also by tweaking the rectangle sizes.
Barry
9476.463 In reply to 9476.459
Barry / Psygorn,
I am unable to repeat the pattern on half issue that you have experienced.
Nevertheless I made a small change to NOD file scaling original rectangle
rather than generating a 2nd rectangle, though it is unlikely that this is the problem.
What is more likely is that the issue is copying of point field into 4 quadrants
prior to generating the voronoi pattern. This should be possible to do with a
single "MovePts" node but it fails to work, necessitating the use of 2 such nodes in series.
It would appear that this 2nd move (copying) is not registering for you.
I am not sure if the reason I have not experienced the same problem is due to the fact
that I am using beta version for Mac M1 processor.
There is one more thing I could try: converting points to point object and then copying them
into quadrants before reconverting back to point field. I imagine that this would radically
increase the computation load since new geometry would be generated with each "MovePts"
operation.
But first let me know if problem persists with this new NOD file
Have a great weekend
9476.464 In reply to 9476.463
Thank you James.
For what it is worth, my computer is still generating half of the torus with unperforated inner and outer skins.
Show messages:  1-4  …  385-404  405-424  425-444  445-464  465-484  485-503
