Elephant Repository
 1-18  …  379-398  399-418  419-438  439-458  459-478  …  499-503
Extention's Nodes
Vector Section
CrossProduct Node
English
EDITED: 2 Jul 2020 by PILOU
9476.420 In reply to 9476.419
what's that thing for?
9476.421 In reply to 9476.420
It's for all operations you can make if you want use Vectors inside your coding...
show Normal of surfaces, graphic's power of something, etc...
9476.422 In reply to 9476.408
Hello Brian,
I had a look to the code. I'm sure you will not find a bug. It seem that the line 35 generates the problem.
The function to create the vector-display works as follow:
- creating a line with length 1 and a cone for the tip of the base vector display
- orient this base vector display to start and end of the vector that should displayed by using "factory('orientlinetoline', that.bVec, bPt0, bPt1, tPt0, tPt1, null, 'scale, stretch');"
but it seems that here is a problem - orientlinetoline generates weired results (tested with MoI V3) when the target has the same orientation as the start orientation especially in the main directions. After the factory is initialised and get other inputs (not in the main dirs) everything works fine as espected. Maybe Michael have a look.
Which Version do you an Pilou use at the moment.
A nice day to all
Karsten
9476.423
When the X and Y are at zero, the Z axis vector defaults to positive. Using James's Node Editor extended version with MoI v4 January 2020 Beta.
EDITED: 17 Jan 2021 by WAYNEHILL5202
9476.424 In reply to 9476.422
Thank you Karsten.
I'm using the nodeeditor version updated by James.
... perceived possible problem with using orient line to line command to place cross product vector...
(Most of post deleted)
EDITED: 4 Jul 2020 by BEMFARMER
9476.425 In reply to 9476.422
<< What version do you use ?
Last version of James & V 4 beta
9476.426
Hello Brian, Hello Wayne,
it's difficult to say what happens. I think that internally a transformation matrix is used for this operation/factory. To create one, you need additional informations like the rotational information that are not given by two lines and certainly not when they are parallel. I had the same problem for the getCrvSFrame. The only info you have here is the direction/tangent of the curve. To create a frame/local coordinate system I used the dominant directions of the main coordinate system. That leads to some weired effects while changing the curves geometry -> flipping axes. Another method would be to use also the center of a soothing circle, but that would fail for straight lines. And yes - it is similar to the gimbal lock. A possible workarround is to add tiny values for the display of the vector - that helps the factory to calculate the orientation.
Maybe Michael can tell us what's going on under the bonnet.
A nice day to all
Karsten
Extention's Nodes
Vector Section
VecMagn Node
English
https://moiscript.weebly.com/vector.html#vecmagn
9476.428 In reply to 9476.426
Possibly relevant are Michael's posts here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9864.5
9476.429 In reply to 9476.422
Hi Karsten,
It looks like a bug in orient line to line, part of how it works is it takes the cross product between the 2 directions to make a vector to rotate around but it is not handling the case well when the 2 directions are parallel when the cross product is undefined. I'll investigate to see if I can fix up that case.
Extention's Nodes
Vector Section
Frame by Vectors Node
English
https://moiscript.weebly.com/vector.html#framebyvecs
I don't know how works ColorVec ? (and if it's terminated)
9476.432 In reply to 9476.431
Hello Pilou,
at first - great job.
ColorVec only make sense for a bundle of vectors - then it colors the vectors dependent of their length.
Nothing more.
A nice day to all
Karsten
9476.433 In reply to 9476.432
So color are randomly following the length or that goes from cold to warm or other ...?
9476.434 In reply to 9476.433
Hello Pilou,
from blue (short) to red (long).
You can also generate vector fields:-)
Have a nice day
Karsten
9476.435 In reply to 9476.429
Hello Michael,
thank you for the detailed information. I will have a look to change the code to avoid this factory.
Have a nice day
Karsten
@Kasten
Perfect! That will closed in Fireworks the Vector Section!
The berturbating was the "Left Output" of the Color Node:)
I suppose i can take your example for the Repository?
9476.437 In reply to 9476.436
Yep!
9476.438 In reply to 9476.437
@ Karsten You don't use the 1.0 Node editor ???
Cool!
So
Extention's Nodes
Vector Section
Colorvec Node
English
https://moiscript.weebly.com/vector.html#colorvec
EDITED: 6 Jul 2020 by PILOU
Show messages:  1-18  …  359-378  379-398  399-418  419-438  439-458  459-478  479-498  499-503
