Elephant Repository
 1-18  …  359-378  379-398  399-418  419-438  439-458  …  499-503
9476.399 In reply to 9476.398
9476.400 In reply to 9476.399
Yes, Pilou.
I was looking at your excellent documentation while writing the above, trying to improve my understanding:-)
The last three sentences were a kind of cross reference...
EDITED: 22 Feb 2020 by BEMFARMER
9476.401 In reply to 9476.400
So added in English and French ;)
http://moiscript.weebly.com/logic.html#bibesplit
http://moiscript.weebly.com/logique.html#bibfsepare
with also a link to the different Modes ( Long, Short, Cross)
http://moiscript.weebly.com/node.html#3modes :)
A little restart after the confinement! :)
Move by Vector
English
https://moiscript.weebly.com/vector.html#movebyvec
Extention's Nodes
Vector Section
Vector Node
English
https://moiscript.weebly.com/vector.html#vector
EDITED: 1 Jul 2020 by PILOU
Extention's Nodes
Vector Section
Add Vector Node
English
https://moiscript.weebly.com/vector.html#add_vector
Extention's Nodes
Vector Section
Substract Vector Node
English
https://moiscript.weebly.com/vector.html#substr_vector
Extention's Nodes
Vector Section
DotProduct Node
English
Seems there i a glitch or i miss something ?
The vertical Vector must be inversed when order is inversed itself!
EDITED: 5 Jun 2020 by PILOU
9476.408 In reply to 9476.407
Using ConvertPts on the point output shows the correct right hand point. (The "inverted" point.)
The vector displayed for the inverted point does seem to be incorrect. I'm investigating the code, which seems very difficult for my brain to understand :-)
In the vector.js code, line 31 creates the vectors, using orient_line_to_line. line 287 codes for the incorrect inverted vector.
this and that do not make sense to me...
EDITED: 5 Jun 2020 by BEMFARMER
9476.409 In reply to 9476.408
So if we must use artificially the Invert node, that say there is a glitch! ;)
Extention's Nodes
Vector Section
VecAngle Node
English
https://moiscript.weebly.com/vector.html#vecangle
9476.411 In reply to 9476.409
There is an excellent series of YouTube videos about vectors and matrices here:
https://www.youtube.com/playlist?list=PLZHQObOWTQDPD3MizzM2xVFitgF8hE_ab
I've watched only #6 and #10, so far. The perspective is about areas and volumes of linear transformations.
#10 is about Cross Product, in 2D and 3D. A negative determinate means that the 3rd vector of the cross product is in the negative direction.
So maybe the vector.js code for Cross Product, line 287, should take the determinant (3D?), and then the code in line 34 modified so that in the case of a negative
determinant, bPt1 would be modified to be (0, 0, -1), instead of (0, 0, +1). (?)
Then the third vector "c" would still follow the right hand rule.
(Note that point "c" is calculated correctly, it is just the vector display that is not correctly oriented for the case of a negative determinant.)
In Pilou's example, when the order of the Cross Product is reversed, the sign of the determinant is reversed. The displayed vector should be negated.
9476.412 In reply to 9476.411
Cool pedagogic serial!
Extention's Nodes
Vector Section
LineByVec Node
English
https://moiscript.weebly.com/vector.html#linebyvect
Extention's Nodes
Vector Section
Rotate Vector Node
English
https://moiscript.weebly.com/vector.html#rotatevec
Extention's Nodes
Vector Section
Line2Vec Node
English
https://moiscript.weebly.com/vector.html#line2vec
Extention's Nodes
Vector Section
VectBy2Pts
English
https://moiscript.weebly.com/vector.html#vecby2pts
Extention's Nodes
Vector Section
Scale Vector node
English
https://moiscript.weebly.com/vector.html#scalevec
Extention's Nodes
Vector Section
PointDist Node
English
Show messages:  1-18  …  339-358  359-378  379-398  399-418  419-438  439-458  459-478  …  499-503
