Elephant Repository
 1-7  …  348-367  368-387  388-407  408-427  428-447  …  488-503
Max's nodelist is very nice.
I finally clicked on the icon of three vertical bars. I'm not sure of the official name. Hamburger bar seems populer :-)
So drag the selected node (or macro) to its desired located.
Clicking, and then click_drag leaves a copy of the node, in shadow, behind the nodelist. (slightly objectionable?, or ?)
Click the three vertical bars again to exit nodelist.
https://stackoverflow.com/questions/34755666/what-is-the-hamburger-menu-icon-called-and-the-three-vertical-dots-icon-called
Eagerly awaiting official names for all of these icons. There are lots of unknown icons on my android tablet, which is connected to Verizon wireless, and also to home network.
It allows MoI forum access, but doesn't quite work like a Windows 10 machine, so is a bit awkward.
p.s. Home network is hooked up to via a persons WIFI "modem", not the PC.
9476.389 In reply to 9476.388
@ Bem You can use some free progs like https://www.realvnc.com for use MOi on your Androïd Tablett!
(the only allowing the 3 mouse buttons for me - the other like Google Remote manage only the left click! )
Even put a Mouse with an OTG USB connector !
And keep or not the fingers "Touch" effect!
= the dream :)
PS and of course any progs running on your PC with only limitations of your PC! (15 meters)
That is the 21 century!
EDITED: 26 Jan 2020 by PILOU
9476.390 In reply to 9476.389
Thank you Pilou for the tips.
9476.391 In reply to 9476.386
Hi Pilou
>> When I press Load in the NodeEditor , and then press Cancel in the Windows of download file i have this... (so I select no file)
I fixed this bug. Thanks
9476.392 In reply to 9476.391
Excellent! ;)
EDITED: 30 Jan 2020 by PILOU
Section Points2
RandomPts Node
English
http://moiscript.weebly.com/point2.html#randompts
9476.396 In reply to 9476.388
To add to documentation of Max's nodelist and documentation of macros:
In Max's nodelist dropdown menu, under Macros, the selections In and Out which apply to macros, are available if and only if a macro node is present in the nodeeditor canvas, and is currently highlighted.
(The dropdown list is long, but it is nice to be able to scan down the list to find a desired node, without having to select multiple menus.)
9476.397 In reply to 9476.396
Split node documentation.
The Split node has 3 versions, corresponding to its 3 menu options, Numbers, Points, or Objects.
Numbers option inputs, and outputs, numarrays.
Points option inputs, and outputs, pointarrays.
Objects option inputs, and outputs, objectlists.
The Split node is multitasking, so a stream of many input items will be processed.
The Split node has a "Mask" boolean (0's & 1's) input, which sends the Num inputs, or Pts inputs, or Obj inputs to either the "1" output, or the "0" output. The input stream is separated into two output streams.
The Split node has 3 modes, Repeat, Long, and Short, which control how the mask is applied to the input stream. Multitasking documentation (should) explain how the modes are applied.
For any one item of the input stream, the Split node does NOT extract its contents. For example, a point does not have its x,y z coordinates extracted.
Under the Basic menu, the "Extract" node, in Points mode, extracts one of 7 elements, X, Y, Z, rX, rY, rZ, or Scale
Under the Points2 menu, the "splitPts" node extracts 10 elements.
EDITED: 22 Feb 2020 by BEMFARMER
9476.399 In reply to 9476.398
9476.400 In reply to 9476.399
Yes, Pilou.
I was looking at your excellent documentation while writing the above, trying to improve my understanding:-)
The last three sentences were a kind of cross reference...
9476.401 In reply to 9476.400
So added in English and French ;)
http://moiscript.weebly.com/logic.html#bibesplit
http://moiscript.weebly.com/logique.html#bibfsepare
with also a link to the different Modes ( Long, Short, Cross)
http://moiscript.weebly.com/node.html#3modes :)
A little restart after the confinement! :)
Move by Vector
English
https://moiscript.weebly.com/vector.html#movebyvec
Extention's Nodes
Vector Section
Vector Node
English
https://moiscript.weebly.com/vector.html#vector
EDITED: 1 Jul 2020 by PILOU
Extention's Nodes
Vector Section
Add Vector Node
English
https://moiscript.weebly.com/vector.html#add_vector
Extention's Nodes
Vector Section
Substract Vector Node
English
https://moiscript.weebly.com/vector.html#substr_vector
Extention's Nodes
Vector Section
DotProduct Node
English
Seems there i a glitch or i miss something ?
The vertical Vector must be inversed when order is inversed itself!
EDITED: 5 Jun 2020 by PILOU
Show messages:  1-7  …  328-347  348-367  368-387  388-407  408-427  428-447  448-467  …  488-503
