Elephant Repository
 1-17  …  338-357  358-377  378-397  398-417  418-437  …  498-503
9476.378 In reply to 9476.377
Modified! :
If you have any lights about my not repositored nodes shown don't hesitate!
Because names of them is not sufficient for explain what they do for me! :(
http://moiscript.weebly.com/curves2.html#spiral
EDITED: 30 Jan 2020 by PILOU
Section Point2
GetCrvSFrame Node
Will be in English :)
http://moiscript.weebly.com/point2.html#getcrvsframe
Happy new year and come back! :)
A little rusted! :D Links will arrive as soon as possible! ;)
Section Object2
Clone4 Node by Brian
English
http://moiscript.weebly.com/objects2.html#clone4
Final Links will be made in some times...
General Repository French / English http://moiscript.weebly.com/biblio-elephant.html
Voronoï Node (By Wayne)
English
http://moiscript.weebly.com/objects2.html#voronoi
Perlin Node BY Wayne
Extentions / Object2
English
http://moiscript.weebly.com/objects2.html#perlinnoise
ImgSampler by Wayne
English
http://moiscript.weebly.com/objects2.html#imgsampler
9476.384
NodeList core extension (an improved version of bundeled ext.mylib extension)
Added Drag and drop support
http://moi.maxsm.net/files/nodeeditor/ext.nodelist.js
Copy it to nodeeditor/core directory (ext.mylib.js can be removed)
EDITED: 7 Mar 2022 by SMIRNOV
9476.385 In reply to 9476.384
Thanks a lot Max!
Also...when will you put your hands on the CORE of N.E. to add some new substantial feature?
Are you waiting the official release of V4?
Have a nice day :)
Don't know if it's a bug ?
When I press Load in the NodeEditor , and then press Cancel in the Windows of download file
i have this... (so I select no file)
EDITED: 26 Jan 2020 by PILOU
9476.387 In reply to 9476.386
Same error is encountered here.
I vaguely recall it occurring several months ago (?)
EDITED: 26 Jan 2020 by BEMFARMER
Max's nodelist is very nice.
I finally clicked on the icon of three vertical bars. I'm not sure of the official name. Hamburger bar seems populer :-)
So drag the selected node (or macro) to its desired located.
Clicking, and then click_drag leaves a copy of the node, in shadow, behind the nodelist. (slightly objectionable?, or ?)
Click the three vertical bars again to exit nodelist.
https://stackoverflow.com/questions/34755666/what-is-the-hamburger-menu-icon-called-and-the-three-vertical-dots-icon-called
Eagerly awaiting official names for all of these icons. There are lots of unknown icons on my android tablet, which is connected to Verizon wireless, and also to home network.
It allows MoI forum access, but doesn't quite work like a Windows 10 machine, so is a bit awkward.
p.s. Home network is hooked up to via a persons WIFI "modem", not the PC.
9476.389 In reply to 9476.388
@ Bem You can use some free progs like https://www.realvnc.com for use MOi on your Androïd Tablett!
(the only allowing the 3 mouse buttons for me - the other like Google Remote manage only the left click! )
Even put a Mouse with an OTG USB connector !
And keep or not the fingers "Touch" effect!
= the dream :)
PS and of course any progs running on your PC with only limitations of your PC! (15 meters)
That is the 21 century!
9476.390 In reply to 9476.389
Thank you Pilou for the tips.
9476.391 In reply to 9476.386
Hi Pilou
>> When I press Load in the NodeEditor , and then press Cancel in the Windows of download file i have this... (so I select no file)
I fixed this bug. Thanks
9476.392 In reply to 9476.391
Excellent! ;)
Section Points2
RandomPts Node
English
http://moiscript.weebly.com/point2.html#randompts
9476.396 In reply to 9476.388
To add to documentation of Max's nodelist and documentation of macros:
In Max's nodelist dropdown menu, under Macros, the selections In and Out which apply to macros, are available if and only if a macro node is present in the nodeeditor canvas, and is currently highlighted.
(The dropdown list is long, but it is nice to be able to scan down the list to find a desired node, without having to select multiple menus.)
9476.397 In reply to 9476.396
Show messages:  1-17  …  318-337  338-357  358-377  378-397  398-417  418-437  438-457  …  498-503
