Elephant Repository
 1-9  …  330-349  350-369  370-389  390-409  410-429  …  490-503
Return to the beast! :)
Not sure I understand all nodes of this section !
Section ArraysEXT
FlipNumArray Node
English
http://moiscript.weebly.com/arraysext.html#flipnumarray
EDITED: 11 Nov 2019 by PILOU
Section ArraysExt
ArraySort Node
English
http://moiscript.weebly.com/arraysext.html#arraysort
Losted in arrays' fields :)
Wanted use the Z height of a cylinder
I supposed that array (1) for the Cylinder, Z will be 3 but...
I must miss something conceptual and / or Synthaxic because result don't give something!
A sort of sampling ? And what is the difference with Remap ?
It's "Out" against "Interp" but that gives exactly the same result !
Section ArraysExt
Remap2 Node
English
http://moiscript.weebly.com/arraysext.html#remap2
Does someone can just show me the different functions of Arrays not yet shown?
(very concise will be sufficient) because I am in the dark! :)
Thx to Karsten for enlight me on this new one :) Some others in waiting holes! :)
See http://moiscript.weebly.com/biblio-elephant.html for see the missing holes!
Section ArraysEXT
BundleArray
English
http://moiscript.weebly.com/arraysext.html#bundlearray
EDITED: 25 Nov 2019 by PILOU
Section Curves2
Spiral Node
English
http://moiscript.weebly.com/curves2.html#spiral
9476.377 In reply to 9476.376
Negative numbers on Turns will reverse spiral direction.
Wayne
9476.378 In reply to 9476.377
Modified! :
If you have any lights about my not repositored nodes shown don't hesitate!
Because names of them is not sufficient for explain what they do for me! :(
EDITED: 30 Jan 2020 by PILOU
Section Point2
GetCrvSFrame Node
Will be in English :)
http://moiscript.weebly.com/point2.html#getcrvsframe
Happy new year and come back! :)
A little rusted! :D Links will arrive as soon as possible! ;)
Section Object2
Clone4 Node by Brian
English
http://moiscript.weebly.com/objects2.html#clone4
Final Links will be made in some times...
General Repository French / English http://moiscript.weebly.com/biblio-elephant.html
Voronoï Node (By Wayne)
English
http://moiscript.weebly.com/objects2.html#voronoi
Perlin Node BY Wayne
Extentions / Object2
English
http://moiscript.weebly.com/objects2.html#perlinnoise
ImgSampler by Wayne
English
http://moiscript.weebly.com/objects2.html#imgsampler
9476.384
NodeList core extension (an improved version of bundeled ext.mylib extension)
Added Drag and drop support
http://moi.maxsm.net/files/nodeeditor/ext.nodelist.js
Copy it to nodeeditor/core directory (ext.mylib.js can be removed)
EDITED: 7 Mar 2022 by SMIRNOV
9476.385 In reply to 9476.384
Thanks a lot Max!
Also...when will you put your hands on the CORE of N.E. to add some new substantial feature?
Are you waiting the official release of V4?
Have a nice day :)
Don't know if it's a bug ?
When I press Load in the NodeEditor , and then press Cancel in the Windows of download file
i have this... (so I select no file)
EDITED: 26 Jan 2020 by PILOU
9476.387 In reply to 9476.386
Same error is encountered here.
I vaguely recall it occurring several months ago (?)
EDITED: 26 Jan 2020 by BEMFARMER
Max's nodelist is very nice.
I finally clicked on the icon of three vertical bars. I'm not sure of the official name. Hamburger bar seems populer :-)
So drag the selected node (or macro) to its desired located.
Clicking, and then click_drag leaves a copy of the node, in shadow, behind the nodelist. (slightly objectionable?, or ?)
Click the three vertical bars again to exit nodelist.
https://stackoverflow.com/questions/34755666/what-is-the-hamburger-menu-icon-called-and-the-three-vertical-dots-icon-called
Eagerly awaiting official names for all of these icons. There are lots of unknown icons on my android tablet, which is connected to Verizon wireless, and also to home network.
It allows MoI forum access, but doesn't quite work like a Windows 10 machine, so is a bit awkward.
p.s. Home network is hooked up to via a persons WIFI "modem", not the PC.
9476.389 In reply to 9476.388
@ Bem You can use some free progs like https://www.realvnc.com for use MOi on your Androïd Tablett!
(the only allowing the 3 mouse buttons for me - the other like Google Remote manage only the left click! )
Even put a Mouse with an OTG USB connector !
And keep or not the fingers "Touch" effect!
= the dream :)
PS and of course any progs running on your PC with only limitations of your PC! (15 meters)
That is the 21 century!
Show messages:  1-9  …  310-329  330-349  350-369  370-389  390-409  410-429  430-449  …  490-503
