Elephant Repository
 1-7  …  328-347  348-367  368-387  388-407  408-427  …  488-503
9476.368 In reply to 9476.367
Hello Pilou,
the stuff in subD is unfinished. It is a while ago that I was working on it. So don't think about this nodes.
I hope that some day someone will pick up the ideas and we can finish it.
Have a nice day
Karsten
9476.369 In reply to 9476.368
...so wait and see! :)
else a new one
Section Objects2
RemoveDupCrv Node
English
http://moiscript.weebly.com/objects2.html#removedupcrv
Return to the beast! :)
Not sure I understand all nodes of this section !
Section ArraysEXT
FlipNumArray Node
English
http://moiscript.weebly.com/arraysext.html#flipnumarray
EDITED: 11 Nov 2019 by PILOU
Section ArraysExt
ArraySort Node
English
http://moiscript.weebly.com/arraysext.html#arraysort
Losted in arrays' fields :)
Wanted use the Z height of a cylinder
I supposed that array (1) for the Cylinder, Z will be 3 but...
I must miss something conceptual and / or Synthaxic because result don't give something!
A sort of sampling ? And what is the difference with Remap ?
It's "Out" against "Interp" but that gives exactly the same result !
Section ArraysExt
Remap2 Node
English
http://moiscript.weebly.com/arraysext.html#remap2
Does someone can just show me the different functions of Arrays not yet shown?
(very concise will be sufficient) because I am in the dark! :)
Thx to Karsten for enlight me on this new one :) Some others in waiting holes! :)
See http://moiscript.weebly.com/biblio-elephant.html for see the missing holes!
Section ArraysEXT
BundleArray
English
http://moiscript.weebly.com/arraysext.html#bundlearray
EDITED: 25 Nov 2019 by PILOU
Section Curves2
Spiral Node
English
http://moiscript.weebly.com/curves2.html#spiral
9476.377 In reply to 9476.376
Negative numbers on Turns will reverse spiral direction.
Wayne
9476.378 In reply to 9476.377
Modified! :
If you have any lights about my not repositored nodes shown don't hesitate!
Because names of them is not sufficient for explain what they do for me! :(
EDITED: 30 Jan 2020 by PILOU
Section Point2
GetCrvSFrame Node
Will be in English :)
http://moiscript.weebly.com/point2.html#getcrvsframe
Happy new year and come back! :)
A little rusted! :D Links will arrive as soon as possible! ;)
Section Object2
Clone4 Node by Brian
English
http://moiscript.weebly.com/objects2.html#clone4
Final Links will be made in some times...
General Repository French / English http://moiscript.weebly.com/biblio-elephant.html
Voronoï Node (By Wayne)
English
http://moiscript.weebly.com/objects2.html#voronoi
Perlin Node BY Wayne
Extentions / Object2
English
http://moiscript.weebly.com/objects2.html#perlinnoise
ImgSampler by Wayne
English
http://moiscript.weebly.com/objects2.html#imgsampler
9476.384
NodeList core extension (an improved version of bundeled ext.mylib extension)
Added Drag and drop support
http://moi.maxsm.net/files/nodeeditor/ext.nodelist.js
Copy it to nodeeditor/core directory (ext.mylib.js can be removed)
EDITED: 7 Mar 2022 by SMIRNOV
9476.385 In reply to 9476.384
Thanks a lot Max!
Also...when will you put your hands on the CORE of N.E. to add some new substantial feature?
Are you waiting the official release of V4?
Have a nice day :)
Don't know if it's a bug ?
When I press Load in the NodeEditor , and then press Cancel in the Windows of download file
i have this... (so I select no file)
EDITED: 26 Jan 2020 by PILOU
9476.387 In reply to 9476.386
Same error is encountered here.
I vaguely recall it occurring several months ago (?)
EDITED: 26 Jan 2020 by BEMFARMER
Show messages:  1-7  …  308-327  328-347  348-367  368-387  388-407  408-427  428-447  …  488-503
