Elephant Repository
 1-13  …  314-333  334-353  354-373  374-393  394-413  …  494-503
Not sure of the function of the "Pinky Point" of this Node!
Was an headache to use! :)
Section Objects2
ScaleUVW Node
English
http://moiscript.weebly.com/objects2.html#scaleuvw
EDITED: 20 Oct 2019 by PILOU
9476.355 In reply to 9476.354
Regarding the point input to ScaleUVW:
For example, with your .nod file:
Place a physical MoI point at say (-5, -5, 0 ), for a reference marker.
Wire a point node, set to ( -5, -5, 0 ), to the pink input to ScaleUVW.
Place a circle at the origin, Top View, say radius 0.5.
Have slider vary from 0 to 10.
Select the circle, and Update Selected node.
Run the node.
Vary the slider.
Slider at zero places the circle at ( -5,-5, 0 ) with radius of zero.
Slider set to 1 leaves the circle at the origin, with radius 0.5.
Slider at 2 places the circle at ( 5, 5, 0 ) with radius of 1.
Slider at 3 places the circle at ( 10, 10, 0 ) with radius of 1.5.
etc.
9476.356 In reply to 9476.355
Thx but i have a result a little different!
X & Y are negative at the screen! Does this normal ?
And for slider at 2 I have not your "5,5" but "2,2" :)
if i don't wire the Slider on scaleUVW (UVW regulated at 2 from start) size don't move!
But the big problem is the negative one!
Send the .nod for see if i have a bug inside the function itself...
EDIT: OK I have found : I must don't wire the POINT! :)
So I have exactly your result! :)
Rest only the negative points for the direction of moving : why we must input (-5,-5) and not (5,5) ?
EDITED: 21 Oct 2019 by PILOU
In fact seems Point is a sort of action Point...
playing only with this Point + Move we can obtain a sort of Mirror! (and of course ScaleUVW)
(but always headaches for find directly the good result! :)
Section Objects2
IntersectObjMp
English
http://moiscript.weebly.com/objects2.html#intersectobjmp
9476.360 In reply to 9476.359
SelectedExt has the code of Selected, with addition of "order" choice, and a bit of code to handle the choice.
I did not delve into the code too much. Formatting of the original Selected has multiple code lines lumped together, which makes it harder to read...
9476.361 In reply to 9476.360
yes but have you an example of what take advantage of use it :)
like
Creation order
A = Cube
B = Sphere
C= Cone
Selection by click
B = Sphere
A= Cube
C = Cone
But now how call object (1), object (2), object (3) for make something with ? (following the method choosen)
the array functions ? Maybe ObjtoArray i will try that!... :)
I don't see also an Array Curve Node?
EDITED: 22 Oct 2019 by PILOU
9476.362 In reply to 9476.361
Hello Pilou,
it's useful for e.g. Loft. If the order of the curves not like you want;-)
Hope that helps!
Have a nice day
Karsten
9476.363 In reply to 9476.362
Maybe also the node "Idx Select" +"Obj to Array" can maybe resolve some of my problems! :)
Aaaaah...many tests and headaches before to undertand that the first array's index was 0 and not 1 ! :D
So after that all works like a charm! :)
Section Objects2
SelectedExt
English
http://moiscript.weebly.com/objects2.html#selectedext
Section Objects2
BrepNameSubObjects Node
English
http://moiscript.weebly.com/objects2.html#brepnamesubobjects
Curious : no need Selected, OutPut Nodes just Click on the SimpleBridge Node!
Section SubD
SimpleBridge Node
English
http://moiscript.weebly.com/subd2.html#simplebridge
I am perplex about this node!
9476.368 In reply to 9476.367
Hello Pilou,
the stuff in subD is unfinished. It is a while ago that I was working on it. So don't think about this nodes.
I hope that some day someone will pick up the ideas and we can finish it.
Have a nice day
Karsten
9476.369 In reply to 9476.368
...so wait and see! :)
else a new one
Section Objects2
RemoveDupCrv Node
English
http://moiscript.weebly.com/objects2.html#removedupcrv
Return to the beast! :)
Not sure I understand all nodes of this section !
Section ArraysEXT
FlipNumArray Node
English
http://moiscript.weebly.com/arraysext.html#flipnumarray
EDITED: 11 Nov 2019 by PILOU
Section ArraysExt
ArraySort Node
English
http://moiscript.weebly.com/arraysext.html#arraysort
Losted in arrays' fields :)
Wanted use the Z height of a cylinder
I supposed that array (1) for the Cylinder, Z will be 3 but...
I must miss something conceptual and / or Synthaxic because result don't give something!
A sort of sampling ? And what is the difference with Remap ?
It's "Out" against "Interp" but that gives exactly the same result !
Section ArraysExt
Remap2 Node
English
http://moiscript.weebly.com/arraysext.html#remap2
Show messages:  1-13  …  294-313  314-333  334-353  354-373  374-393  394-413  414-433  …  494-503
