Elephant Repository
 1-16  …  297-316  317-336  337-356  357-376  377-396  …  497-503
9476.337 In reply to 9476.334
It appears that the camera is moving, not the target.
The camera can move in many directions, not just revolving around the target.
Edit, As per Pilou, the target can also move:-)
Typo: Save is On or Off, not Own.
Some clarification of how to make an mpeg or avi would be nice.
Frame I understand to be one picture, in camera language, rather than MoI frame, although maybe they are interrelated?
EDITED: 17 Oct 2019 by BEMFARMER
9476.338 In reply to 9476.337
Why not ? You must just drawing something moving...
9476.339 In reply to 9476.338
Touche'
Sections Infos
Curvature Node
English
http://moiscript.weebly.com/infos.html#curvature
Section Infos
ShowFrame
English
http://moiscript.weebly.com/infos.html#showframe
Section Infos
BoundingBoxes Node
English
http://moiscript.weebly.com/infos.html#boundingboxes
Another time need to truncate the result! :)
Maths node has not this function and i don't see how enter inside Maths node another thing than the presets! :(
As soon as I enter another thing it's remplaced by a preset!
PS What is "STL" it's for Print 3D or it's another thing ?
Section Infos
StlVolume
http://moiscript.weebly.com/infos.html#stlvolume
9476.344 In reply to 9476.343
From 2015, Dinos/Max Calculate volume from Stereolithograpy polygon triangles:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7421.13
https://stackoverflow.com/questions/6518404/how-do-i-calculate-the-volume-of-an-object-stored-in-stl-files
Karsten 2017 Infonodes:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.279
Javascript has truncation functions. Maybe place a math node between Volume and Text, and use one of the Javascript truncate or round functions?
There is .toFixed(2)...StackOverflow has brief code to fix up .toFixed...
rounded_number = Math.round(number * 100) / 100 (from Geeks for Geeks)
To truncate an objectlist, I think there must be another node to do the truncation. An array type of node...?
Maybe Stream2Array? There is a "max" input...
9476.345 In reply to 9476.344
I will exam all that...but i wish only nodes..not want to explore the code ;)
<< Maybe place a math node between Volume and Text
Yes how put materially another thing than the existing presets ???
Stream2Array? There is a "max" input ...what is the use of this Array ?
else
Section Infos
StlAera Node
English
http://moiscript.weebly.com/infos.html#stlaera
EDITED: 18 Oct 2019 by PILOU
I suppose that is the same Camera to use than Camera2 Node
(go there for node to load and see animation! ) http://moiscript.weebly.com/r2d3.html#camera2
Section Infos
Camera Node
English
http://moiscript.weebly.com/infos.html#camera
Don't know that exists an Importer STL to Moi!!!
Section Import
STL Import Node
http://moiscript.weebly.com/import.html#stlimport
Section Objects2
TrimObject
English
http://moiscript.weebly.com/objects2.html#trimobj
Section Objects2
ExtractPts Node
English
http://moiscript.weebly.com/objects2.html#extractpts
Section Objects2
SetStyle Node
English
http://moiscript.weebly.com/objects2.html#setstyle
EDITED: 20 Oct 2019 by PILOU
9476.353 In reply to 9476.352
Section Objects2
RandomObj Node
English
http://moiscript.weebly.com/objects2.html#randomobj
Not sure of the function of the "Pinky Point" of this Node!
Was an headache to use! :)
Section Objects2
ScaleUVW Node
English
http://moiscript.weebly.com/objects2.html#scaleuvw
9476.355 In reply to 9476.354
Regarding the point input to ScaleUVW:
For example, with your .nod file:
Place a physical MoI point at say (-5, -5, 0 ), for a reference marker.
Wire a point node, set to ( -5, -5, 0 ), to the pink input to ScaleUVW.
Place a circle at the origin, Top View, say radius 0.5.
Have slider vary from 0 to 10.
Select the circle, and Update Selected node.
Run the node.
Vary the slider.
Slider at zero places the circle at ( -5,-5, 0 ) with radius of zero.
Slider set to 1 leaves the circle at the origin, with radius 0.5.
Slider at 2 places the circle at ( 5, 5, 0 ) with radius of 1.
Slider at 3 places the circle at ( 10, 10, 0 ) with radius of 1.5.
etc.
9476.356 In reply to 9476.355
Thx but i have a result a little different!
X & Y are negative at the screen! Does this normal ?
And for slider at 2 I have not your "5,5" but "2,2" :)
if i don't wire the Slider on scaleUVW (UVW regulated at 2 from start) size don't move!
But the big problem is the negative one!
Send the .nod for see if i have a bug inside the function itself...
EDIT: OK I have found : I must don't wire the POINT! :)
So I have exactly your result! :)
Rest only the negative points for the direction of moving : why we must input (-5,-5) and not (5,5) ?
EDITED: 21 Oct 2019 by PILOU
Show messages:  1-16  …  277-296  297-316  317-336  337-356  357-376  377-396  397-416  …  497-503
