Elephant Repository
 1-8  …  289-308  309-328  329-348  349-368  369-388  …  489-503
Section r2d3
Quartz2 Node
English
http://moiscript.weebly.com/r2d3.html#quartz2
EDITED: 16 Oct 2019 by PILOU
Section r2d3
ObjToArray2
Difference than native ObjToArray is "StartEnd" but i don't know what is it! :)
Thanks to show me an example!
Section r2d3
Camera2 Node
What is effect of Idx ? Encoder ? Effect of save (i suppose save to file ?) and how to enable it ? (press something ?)
9476.332 In reply to 9476.331
Hi Pilou.
I did a little testing with r2d3's camera1.nod. https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.861
With Frames set to, for example, 100
Frames is the number of camera pictures as test1.png, test2.png, ... test100.png, which can be snapped (picture taken).
(So maybe set Frames to say 10, for testing purposes.)
Idx is the actual number of pictures which are in the process of being taken during a Run.
I used a USB stick for the File Path entry: H:\
I placed an Ascher diamond at the origin, in Top View, for a Target.
So now, with Idx set to 0, turn Save to ON, and press Run.
100 png pictures will be taken of the Ascher diamond as it rotates, and placed in 100 png files in the H:\ directory.
(Not a very exciting set of pictures:-)
The Idx count of pictures taken increases up to 100.
Then I guess some other software can be used to make a movie from the png's
ps Setting File Path entry to: H:\Ascher will create the png's with Aschertest1.png, Aschertest2.png,... , in the H:\ directory.
Setting File Path entry to: H:\Ascher\ with the ending backslash, will use the subdirectory Ascher for the saved files test1.png, test2.png, etc.
(The subdirectory Ascher must be manually created under H:\ before using it as the File Path entry.)
Encoder or Enc, seems to be set to .png by default, although there is also .avi in the next line of code. .avi does not seem to be used. ???
I do not know how or if Camera2 can make a video. Maybe someone else can decipher the camera2 video code?
The old Camera code mentions ffmpeg. Also jones. Maybe some other software is needed?
To re-run the camera with save, reset the Idx value to 0.
EDITED: 17 Oct 2019 by BEMFARMER
9476.333 In reply to 9476.332
Thx i will examine that!
In fact there was a ready macro by d2r3
So...
Section d2r3
Camera2 Node
English
http://moiscript.weebly.com/r2d3.html#camera2
EDITED: 17 Oct 2019 by PILOU
Should have a number of decimal!!! :)
Section Infos
Curve Length Node
English
http://moiscript.weebly.com/infos.html#curvelength
9476.336 In reply to 9476.335
Section Infos
BoundingBox Infos
English
http://moiscript.weebly.com/infos.html#boundingboxinfos
9476.337 In reply to 9476.334
It appears that the camera is moving, not the target.
The camera can move in many directions, not just revolving around the target.
Edit, As per Pilou, the target can also move:-)
Typo: Save is On or Off, not Own.
Some clarification of how to make an mpeg or avi would be nice.
Frame I understand to be one picture, in camera language, rather than MoI frame, although maybe they are interrelated?
9476.338 In reply to 9476.337
Why not ? You must just drawing something moving...
9476.339 In reply to 9476.338
Touche'
Sections Infos
Curvature Node
English
http://moiscript.weebly.com/infos.html#curvature
Section Infos
ShowFrame
English
http://moiscript.weebly.com/infos.html#showframe
Section Infos
BoundingBoxes Node
English
http://moiscript.weebly.com/infos.html#boundingboxes
Another time need to truncate the result! :)
Maths node has not this function and i don't see how enter inside Maths node another thing than the presets! :(
As soon as I enter another thing it's remplaced by a preset!
PS What is "STL" it's for Print 3D or it's another thing ?
Section Infos
StlVolume
http://moiscript.weebly.com/infos.html#stlvolume
9476.344 In reply to 9476.343
From 2015, Dinos/Max Calculate volume from Stereolithograpy polygon triangles:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7421.13
https://stackoverflow.com/questions/6518404/how-do-i-calculate-the-volume-of-an-object-stored-in-stl-files
Karsten 2017 Infonodes:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.279
Javascript has truncation functions. Maybe place a math node between Volume and Text, and use one of the Javascript truncate or round functions?
There is .toFixed(2)...StackOverflow has brief code to fix up .toFixed...
rounded_number = Math.round(number * 100) / 100 (from Geeks for Geeks)
To truncate an objectlist, I think there must be another node to do the truncation. An array type of node...?
Maybe Stream2Array? There is a "max" input...
9476.345 In reply to 9476.344
I will exam all that...but i wish only nodes..not want to explore the code ;)
<< Maybe place a math node between Volume and Text
Yes how put materially another thing than the existing presets ???
Stream2Array? There is a "max" input ...what is the use of this Array ?
else
Section Infos
StlAera Node
English
http://moiscript.weebly.com/infos.html#stlaera
EDITED: 18 Oct 2019 by PILOU
I suppose that is the same Camera to use than Camera2 Node
(go there for node to load and see animation! ) http://moiscript.weebly.com/r2d3.html#camera2
Section Infos
Camera Node
English
http://moiscript.weebly.com/infos.html#camera
Don't know that exists an Importer STL to Moi!!!
Section Import
STL Import Node
http://moiscript.weebly.com/import.html#stlimport
Show messages:  1-8  …  269-288  289-308  309-328  329-348  349-368  369-388  389-408  …  489-503
