Elephant Repository
 1-3  …  264-283  284-303  304-323  324-343  344-363  …  484-503
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#reconstructcurve
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#rebuildcurve
Section Curves2
Flip Node
English
http://moiscript.weebly.com/curves2.html#flipcurve can maybe more smaller :)
Section Curves2
Extend Node
English
http://moiscript.weebly.com/curves2.html#extend
Section Curves2
UnwrapCurve Node
English
http://moiscript.weebly.com/curves2.html#unwrapcurve
Section r2d3
Selectededges Node
English
http://moiscript.weebly.com/r2d3.html#selectededges
Section r2d3
Fillet2 Node
English
http://moiscript.weebly.com/r2d3.html#fillet2
Section SubD
PolyLoft Node
English
http://moiscript.weebly.com/subd2.html#polyloft
Section SubD
ConvertCurveToPoly
English
http://moiscript.weebly.com/subd2.html#convertcurvetopoly
I have some perplexity about Import/ STLImport Node !
What put between it and the OuPut ? Direct link don't work! :(
9476.314 In reply to 9476.313
Hello Pilou,
stl-import works only with ASCII stl-files.
Sometimes there are some other problems also.
Please check it.
Have a nice weekend
Karsten
9476.315 In reply to 9476.314
I will study that :)
Section SubD
Join Node
English
http://moiscript.weebly.com/subd2.html#join
Join several Curves in only One!
At the end run this ShortCut for have directly normal selection because it's not enabled at the end of the Nodes!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
EDITED: 12 Oct 2019 by PILOU
Section SubD
The Simple Bridge is not so simple!
Accept not faces but surfaces ??? and i am sucked again with this simplicity! :)
Normally that must make that I suppose...
but...
9476.318 In reply to 9476.317
Section SubD
Same problem for Connection Node... :(
Section SubD
SelCenterPlane
English
http://moiscript.weebly.com/subd2.html#selcenterplane
Section SubD
SubD node
English
http://moiscript.weebly.com/subd2.html#subd
Display texts + Values resolved with another headaches !:)
Was not so evident!
And now i must find something more elaborated for the mirror! A new fight with the Frame in perspective :)
For the moment it's only one orientation refexion so a little lite! :)
And as I took symmetric objects mirror is not remarquable! <:0)
so here a more understandable!
Section Transform2
Mirror Node English
http://moiscript.weebly.com/transform2.html#mirror
EDITED: 13 Oct 2019 by PILOU
Section Transform2
StereoProject Node
English
http://moiscript.weebly.com/transform2.html#stereoproject
Not hyper ergonomic ...i am discovering all that ...but... :)
Mirror Node again
Show messages:  1-3  …  244-263  264-283  284-303  304-323  324-343  344-363  364-383  …  484-503
