Elephant Repository
 1-19  …  260-279  280-299  300-319  320-339  340-359  …  500-503
Section Curves2
Helix Node
English
http://moiscript.weebly.com/curves2.html#helix
@ karsten : i have resolved my headache! :)
So simple! :)
Section Curves2
CurveFillet Node
English
http://moiscript.weebly.com/curves2.html#curvefillet
EDITED: 9 Oct 2019 by PILOU
Section Curves2
CurveBlend Fillet Node
English
http://moiscript.weebly.com/curves2.html#curveblend
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#reconstructcurve
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#rebuildcurve
Section Curves2
Flip Node
English
http://moiscript.weebly.com/curves2.html#flipcurve can maybe more smaller :)
Section Curves2
Extend Node
English
http://moiscript.weebly.com/curves2.html#extend
Section Curves2
UnwrapCurve Node
English
http://moiscript.weebly.com/curves2.html#unwrapcurve
Section r2d3
Selectededges Node
English
http://moiscript.weebly.com/r2d3.html#selectededges
Section r2d3
Fillet2 Node
English
http://moiscript.weebly.com/r2d3.html#fillet2
Section SubD
PolyLoft Node
English
http://moiscript.weebly.com/subd2.html#polyloft
Section SubD
ConvertCurveToPoly
English
http://moiscript.weebly.com/subd2.html#convertcurvetopoly
I have some perplexity about Import/ STLImport Node !
What put between it and the OuPut ? Direct link don't work! :(
9476.314 In reply to 9476.313
Hello Pilou,
stl-import works only with ASCII stl-files.
Sometimes there are some other problems also.
Please check it.
Have a nice weekend
Karsten
9476.315 In reply to 9476.314
I will study that :)
Section SubD
Join Node
English
http://moiscript.weebly.com/subd2.html#join
Join several Curves in only One!
At the end run this ShortCut for have directly normal selection because it's not enabled at the end of the Nodes!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
EDITED: 12 Oct 2019 by PILOU
Section SubD
The Simple Bridge is not so simple!
Accept not faces but surfaces ??? and i am sucked again with this simplicity! :)
Normally that must make that I suppose...
but...
9476.318 In reply to 9476.317
Section SubD
Same problem for Connection Node... :(
Section SubD
SelCenterPlane
English
http://moiscript.weebly.com/subd2.html#selcenterplane
Show messages:  1-19  …  240-259  260-279  280-299  300-319  320-339  340-359  360-379  …  500-503
