Elephant Repository
 1-18  …  259-278  279-298  299-318  319-338  339-358  …  499-503
9476.299 In reply to 9476.298
Hi Karsten,
I am getting an assert failure when doing "apply". After Ignore All, the two vectors cannot be deleted from MoI.
Perhaps unrelated, closing MoI with large nodeeditor canvas, and reopening MoI4beta and nodeeditor results in a large canvas with white top area hidden, and the canvas cannot be moved, unless the canvas is side dragged to be skinnier. (Cannot reproduce this effect...)
I'm trying to understand the frames.
Max incorporated Frames into the PointArray datatype. There is an old post that he made about this accomplishment.
Regarding FrameByVecs:
Adding ConvertPts and Output to the point output of FrameByVecs shows that its output Frame is located as a point at the common beginning point of the two vector inputs,
xdir and ydir.
xdir input establishes the x direction of the output frame. The ydir input does not have to be in the y direction of MoI.
Orthogonality to xdir doesn't seem to matter, as long as ydir has a nonzero value for y or z arrow point of the second input vector.
Karsten's example node uses z = 5 for the ydir vector, but y = 5 would also work, as well as other combinations of z and y.
The axis labels are still not showing up in MoI4 beta.
The addition of 3 outputs to the three vector definition points shows the 3 points to be at the three arrow tips of the 3 Line2Vec nodes.
-Brian
EDITED: 8 Oct 2019 by BEMFARMER
Section Curves2
Helix Node
English
http://moiscript.weebly.com/curves2.html#helix
@ karsten : i have resolved my headache! :)
So simple! :)
Section Curves2
CurveFillet Node
English
http://moiscript.weebly.com/curves2.html#curvefillet
EDITED: 9 Oct 2019 by PILOU
Section Curves2
CurveBlend Fillet Node
English
http://moiscript.weebly.com/curves2.html#curveblend
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#reconstructcurve
Section Curves2
RebuildCurve Node
English
http://moiscript.weebly.com/curves2.html#rebuildcurve
Section Curves2
Flip Node
English
http://moiscript.weebly.com/curves2.html#flipcurve can maybe more smaller :)
Section Curves2
Extend Node
English
http://moiscript.weebly.com/curves2.html#extend
Section Curves2
UnwrapCurve Node
English
http://moiscript.weebly.com/curves2.html#unwrapcurve
Section r2d3
Selectededges Node
English
http://moiscript.weebly.com/r2d3.html#selectededges
Section r2d3
Fillet2 Node
English
http://moiscript.weebly.com/r2d3.html#fillet2
Section SubD
PolyLoft Node
English
http://moiscript.weebly.com/subd2.html#polyloft
Section SubD
ConvertCurveToPoly
English
http://moiscript.weebly.com/subd2.html#convertcurvetopoly
I have some perplexity about Import/ STLImport Node !
What put between it and the OuPut ? Direct link don't work! :(
9476.314 In reply to 9476.313
Hello Pilou,
stl-import works only with ASCII stl-files.
Sometimes there are some other problems also.
Please check it.
Have a nice weekend
Karsten
9476.315 In reply to 9476.314
I will study that :)
Section SubD
Join Node
English
http://moiscript.weebly.com/subd2.html#join
Join several Curves in only One!
At the end run this ShortCut for have directly normal selection because it's not enabled at the end of the Nodes!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
EDITED: 12 Oct 2019 by PILOU
Section SubD
The Simple Bridge is not so simple!
Accept not faces but surfaces ??? and i am sucked again with this simplicity! :)
Normally that must make that I suppose...
but...
9476.318 In reply to 9476.317
Section SubD
Same problem for Connection Node... :(
Show messages:  1-18  …  239-258  259-278  279-298  299-318  319-338  339-358  359-378  …  499-503
