Elephant Repository
 1-6  …  227-246  247-266  267-286  287-306  307-326  …  487-503
Notice that the nodes in construct2.js are all set up to use the Info button.
The getExtraMenuOptions code has already been inserted :D
All that is needed is to write the .html Info documentation files for each such node.
ps, How does one change to say the FR, French version?
Changing lang.js to "FR" is not sufficient.
9476.268 In reply to 9476.267
<< How does one change to say the FR, French version?
It's not automatic when you enable French inside Moi's Options ?
EDITED: 5 Oct 2019 by PILOU
9476.269 In reply to 9476.268
Thank you Pilou. MoI is now in French for a temporary test, after using MoI Option button, language version, set to French.
I'm still unable to get a French .html documentation info window...
EDITED: 5 Oct 2019 by BEMFARMER
9476.270 In reply to 9476.269
For progress in getting node Info documentation in French to work, please see
https://moi3d.com/forum/index.php?webtag=MOI&msg=9518.6
Text has no difficulties! :)
Text Node
English
http://moiscript.weebly.com/construct2.html#text
You can now have directly access to each No Native Node itself from the forum! :)
see previous posts https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.247 or futur following ;)
or All not native ;) http://moiscript.weebly.com/all-nodes.html#allnodenonative
PS direct access from a section istself will be made when a section will be finished!
Edit direct access is done! http://moiscript.weebly.com/biblio-elephant.html#allnodenonative
EDITED: 6 Oct 2019 by PILOU
A more classic example of RailRevolve! ;)
I take a Point as center of Axe : seems vertical by default!
Wished a simple method for input a "frame" inclined!
I am perplex : i don't find the trick for input the right thing inside the Frame!
How do you process?
this Selected --ObjtoArray --Frame like following don't work! :(
Shell node
English
http://moiscript.weebly.com/construct2.html#shell
If you have a volume must be separated for surfaces wanted!
Seems BrepNameSubOject necessary
Flip or Center line...(for volume)
Fillet2 Node
English
http://moiscript.weebly.com/construct2.html#fillet2
Global Fillet on volume(s)
Ok i haved finished the Section Not Native Construct2 all English ;) Next will be Curve2
...except these 2 little things where i am sucked! :(
if you have some ideas ?
9476.282 In reply to 9476.281
For Frame, try vector\FrameByVec.
Right hand rule with two orthogonal vectors yields z axis.
I find a lot of the point characteristics confusing:-)
Lots of luck with SplitPts and PointExt.
There are also Infos/ShowFrame
and Points2/getCrvSFrame
Text2:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.936
EDITED: 7 Oct 2019 by BEMFARMER
9476.283 In reply to 9476.282
Thx i will test all that!
About the Text2 that works fine for "number" but that I want is add a Text say a paragraph from any source.
I know that I can input it in the case box of the node itself...but want input from a file ...
Ps about the files from r2d3 i can't have the "concat2" who stay red ! (even loaded the r2d3 .js in extension folder )
else loaded the waves by r2d3 ;)
EDITED: 7 Oct 2019 by PILOU
About vectors not better...but it's my lack of use and what is a vector inside Elephant! :)
This really draw only the "red ARROW"! Pity because that was cool for draw a vector! :)
I always don't know what the "Frame" is really wanted!
( seems I have a line selected in the good direction)
Not better with that! :) Mystery always!
(i run it of course... this image if before the new run ...line is not yet selected)
Show messages:  1-6  …  207-226  227-246  247-266  267-286  287-306  307-326  327-346  …  487-503
