Elephant Repository
 1-2  …  223-242  243-262  263-282  283-302  303-322  …  503
Construct2/ Isocurves
Seems something is missing ? Only horizontal ...
Hello Pilou!
You're really doing a SUPERB job with all this docs and tutorials!!!
Hats off!
9476.265 In reply to 9476.264
Thx but a long race and will be soon slowed-down because Nodes are not so evident! :)
IsoCrvs Node
English
http://moiscript.weebly.com/construct2.html#isocrvs
In fact E0..E3 are not missing but seems work only a Surface not on a volume!
You must Display the volume if you want see it in the same time than the IsoCurves!
EDITED: 5 Oct 2019 by PILOU
Not Native Nodes By Sections ...that is some frightening! :)
English (Native and not Native)
http://moiscript.weebly.com/all-nodes.html#allnodenonative
Array Ext
Basics2
Points2
Construct2
Curves2
Import
Infos
SubD
Obj2
Transform2
Vectors
Notice that the nodes in construct2.js are all set up to use the Info button.
The getExtraMenuOptions code has already been inserted :D
All that is needed is to write the .html Info documentation files for each such node.
ps, How does one change to say the FR, French version?
Changing lang.js to "FR" is not sufficient.
9476.268 In reply to 9476.267
<< How does one change to say the FR, French version?
It's not automatic when you enable French inside Moi's Options ?
9476.269 In reply to 9476.268
Thank you Pilou. MoI is now in French for a temporary test, after using MoI Option button, language version, set to French.
I'm still unable to get a French .html documentation info window...
EDITED: 5 Oct 2019 by BEMFARMER
9476.270 In reply to 9476.269
For progress in getting node Info documentation in French to work, please see
https://moi3d.com/forum/index.php?webtag=MOI&msg=9518.6
Text has no difficulties! :)
Text Node
English
http://moiscript.weebly.com/construct2.html#text
You can now have directly access to each No Native Node itself from the forum! :)
see previous posts https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.247 or futur following ;)
or All not native ;) http://moiscript.weebly.com/all-nodes.html#allnodenonative
PS direct access from a section istself will be made when a section will be finished!
Edit direct access is done! http://moiscript.weebly.com/biblio-elephant.html#allnodenonative
EDITED: 6 Oct 2019 by PILOU
A more classic example of RailRevolve! ;)
I take a Point as center of Axe : seems vertical by default!
Wished a simple method for input a "frame" inclined!
I am perplex : i don't find the trick for input the right thing inside the Frame!
How do you process?
this Selected --ObjtoArray --Frame like following don't work! :(
Shell node
English
http://moiscript.weebly.com/construct2.html#shell
If you have a volume must be separated for surfaces wanted!
Seems BrepNameSubOject necessary
Flip or Center line...(for volume)
Fillet2 Node
English
http://moiscript.weebly.com/construct2.html#fillet2
Global Fillet on volume(s)
Ok i haved finished the Section Not Native Construct2 all English ;) Next will be Curve2
...except these 2 little things where i am sucked! :(
if you have some ideas ?
9476.282 In reply to 9476.281
For Frame, try vector\FrameByVec.
Right hand rule with two orthogonal vectors yields z axis.
I find a lot of the point characteristics confusing:-)
Lots of luck with SplitPts and PointExt.
There are also Infos/ShowFrame
and Points2/getCrvSFrame
Text2:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.936
EDITED: 7 Oct 2019 by BEMFARMER
Show messages:  1-2  …  203-222  223-242  243-262  263-282  283-302  303-322  323-342  …  503
