Elephant Repository
 1-19  …  220-239  240-259  260-279  280-299  300-319  …  500-503
9476.260 In reply to 9476.258
Hi Pilou
BrepnameSuObjects is useless with Fllet2
EDITED: 9 May 2020 by FINEMA
9476.261 In reply to 9476.260
Cool so more speedy! But seems you can't select edge(s) wished so a "global fillet ? ! (and I see you use the French version! ;)
And about the Construct2/Fillet how do you manage and use the adjacent Faces ?
If before i select Face(s) against Edges i have no result...
If I select only Edges I have no result...
If I select Edges + Faces I have no result...
EDITED: 5 Oct 2019 by PILOU
Construct2/ Isocurves
Seems something is missing ? Only horizontal ...
Hello Pilou!
You're really doing a SUPERB job with all this docs and tutorials!!!
Hats off!
9476.265 In reply to 9476.264
Thx but a long race and will be soon slowed-down because Nodes are not so evident! :)
IsoCrvs Node
English
http://moiscript.weebly.com/construct2.html#isocrvs
In fact E0..E3 are not missing but seems work only a Surface not on a volume!
You must Display the volume if you want see it in the same time than the IsoCurves!
Not Native Nodes By Sections ...that is some frightening! :)
English (Native and not Native)
http://moiscript.weebly.com/all-nodes.html#allnodenonative
Array Ext
Basics2
Points2
Construct2
Curves2
Import
Infos
SubD
Obj2
Transform2
Vectors
Notice that the nodes in construct2.js are all set up to use the Info button.
The getExtraMenuOptions code has already been inserted :D
All that is needed is to write the .html Info documentation files for each such node.
ps, How does one change to say the FR, French version?
Changing lang.js to "FR" is not sufficient.
9476.268 In reply to 9476.267
<< How does one change to say the FR, French version?
It's not automatic when you enable French inside Moi's Options ?
9476.269 In reply to 9476.268
Thank you Pilou. MoI is now in French for a temporary test, after using MoI Option button, language version, set to French.
I'm still unable to get a French .html documentation info window...
EDITED: 5 Oct 2019 by BEMFARMER
9476.270 In reply to 9476.269
For progress in getting node Info documentation in French to work, please see
https://moi3d.com/forum/index.php?webtag=MOI&msg=9518.6
Text has no difficulties! :)
Text Node
English
http://moiscript.weebly.com/construct2.html#text
You can now have directly access to each No Native Node itself from the forum! :)
see previous posts https://moi3d.com/forum/index.php?webtag=MOI&msg=9476.247 or futur following ;)
or All not native ;) http://moiscript.weebly.com/all-nodes.html#allnodenonative
PS direct access from a section istself will be made when a section will be finished!
Edit direct access is done! http://moiscript.weebly.com/biblio-elephant.html#allnodenonative
EDITED: 6 Oct 2019 by PILOU
A more classic example of RailRevolve! ;)
I take a Point as center of Axe : seems vertical by default!
Wished a simple method for input a "frame" inclined!
I am perplex : i don't find the trick for input the right thing inside the Frame!
How do you process?
this Selected --ObjtoArray --Frame like following don't work! :(
Shell node
English
http://moiscript.weebly.com/construct2.html#shell
If you have a volume must be separated for surfaces wanted!
Seems BrepNameSubOject necessary
Flip or Center line...(for volume)
Show messages:  1-19  …  200-219  220-239  240-259  260-279  280-299  300-319  320-339  …  500-503
