Elephant Repository
 1-7  …  168-187  188-207  208-227  228-247  248-267  …  488-503
Does it possible to Show Hide the Grid of the NodeEditor ?
Interp Node ( English French)
http://moiscript.weebly.com/basic.html
The ultima Native last is the "Quartz" Node : i suppose that is a timer but i have not many ideas for use it! :)
If you have a little example ? That will be fine! :)
The next one "Not Native Node" will maybe a little more difficult for me! :)
I would probably need some big help from the creators!
But before to begin this monstruous part i will make some fun training with the natives ones for some relaxing! :)
9476.212 In reply to 9476.208
re: Show/Hide grid of nodeeditor.
Maybe make a white on white grid version of nodeeditor based upon James's alternate color scheme.
This would appear grid-less?
Grid-less color scheme could be assigned a hotkey, and .nod program opened in it?
Could grid colors be changed in an existing/open node canvas, with some added code?
When moving nodes, the nodes have a "snap to nearest grid" feature.
9476.213 In reply to 9476.210
Small example of Quartz node
EDITED: 17 Jan 2021 by WAYNEHILL5202
9476.214 In reply to 9476.212
@Bem I have believed seen somewhere that we can Show / Hide Grid but maybe i have dreamed :)
9476.215 In reply to 9476.213
@WayneHill Many thanks...Bravo! I can now finish my Native Nodes Section!
Excellent! I see the potential! Perfect for animation! ;)
As you can see i didn't made many efforts! Copy Move your original Object
Changed Tic-Tac to Cycled and changed "Value" parameters! :)
EDITED: 20 Sep 2019 by PILOU
Don't find what is this Const ??? It don't appears in the Quartz Info Pannel ???
Not a problem but... :)
The last of the Elephant Native Nodes!
You can find all that here ! http://moiscript.weebly.com/biblio-elephant.html In English! ;) and of course in French also! :)
I will make a little break for use them for the fun before to start the Extention Nodes section! :D
So the Quartz Node : a funny one! Thanks to Waynehill!
9476.218 In reply to 9476.216
Hz is for Hertz, the frequency or cycles per second.
In other words, the speed of the clock, or the speed of the twisting.
In general terms, a frequency of 1 hertz means that something happens once a second, but in the
nodeeditor program, the speed may be faster or slower. So it is the relative speed.
Examples:
Hz = 0.1 is slow twist...
Hz = 5 for faster twist...
The frequency could be measured, but may vary depending upon computer?, software load? etc ?
EDITED: 20 Sep 2019 by BEMFARMER
9476.219 In reply to 9476.218
OK ...as i seen no notable difference with little or more bigger numbers i was perplex!
Thanks for the explanation!
9476.220 In reply to 9476.219
On my computer, your excellent quartz/twist node runs slow at HZ = .1, and runs
rapidly at HZ = 1 or 2...
Maybe computer speed makes a difference?
9476.221 In reply to 9476.220
Thx for precisions!
Just for say that i made a little more better UI for directly access to the Nodes! :)
French done, English half done (will be finished this evening! :)
just test Quartz who seems indispensable for make animation!
EDITED: 23 Sep 2019 by PILOU
9476.223 In reply to 9476.196
Hi Pilou
How did you create this? Looks awesome.
9476.224 In reply to 9476.223
Sorry my speed example above was not very raffined! :)
This other one following not many more but for explain the concept that is very sufficient!
Something like that...draw anything (here a simple box) out of the origin for avoid to manage the center et voilĂ  :)
I don't want imagine that is possible to do! :D
Really funny and very speedy to do! Beauty of the simplicity! Small is beautiful ! :)
Ok as promised French/ English sweet UI Native Nodes is done for accelerate accessibility ! :)
Maybe i will make also a graphic Nodes Clickable...as i have now the "anchors" ;)
Not exactly each Native Nodes one by one clickable but... :)
(French / English)
http://moiscript.weebly.com/all-nodes.html
Can you validate the process for make such sort of thing! http://moiscript.weebly.com/uploads/3/9/3/8/3938813/easy.nod
Progression seems also indispensable for integrate some numerous data for create some sequential profils etc...if you don't want drawing first outof the Node then Select them...but maybe you have anothers strategy ?
As I use only "Native nodes" for the moment there is no "Scale" directly for the objects! (for the points yes if am i right)
Another thing : does it normal that the "Save" of the "Nodes" don't save the objects selected ?
EDITED: 24 Sep 2019 by PILOU
Show messages:  1-7  …  148-167  168-187  188-207  208-227  228-247  248-267  268-287  …  488-503
