Elephant Repository
 1-19  20-39  40-59  60-79  …  500-503
Does exist a ShortCut for reduct/extend all the nodes in the same time ?
And will correct a little error about Mode for the Circle(as previous node demo example) !
the 3 "modes" Short , Long, Cross are not for decimal precision but for use of Array! :)
(i have no example of the "Cross mode" )
so corrected! :)
EDITED: 24 Aug 2019 by PILOU
Use of the Array modes :)
Added this :)
http://moiscript.weebly.com/node.html
​For the moment we don't have control over the normal selection of objects after an Elephant session!
It is therefore necessary to add this Script as a shortcut before it will be integrated directly into the output of a node!
script: var objs = me.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i) { var obj = objs.item(i); obj.setHitTest( true); }
EDITED: 26 Aug 2019 by PILOU
Some training for refind the logic of Nodes! Not so trivial :) (and some instability of the not native functions: see next post)
Have you this same error message with this little "nodes" ? (above one)
I have only 8 giga hard memory but don't know if this explain that...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/toto.nod
9476.26 In reply to 9476.25
Your node worked here, and made a "donut".
Windows 10, 16GB ram, nod works for either MoI4Beta or MoI3.
(Recent ssd reinstall, with James updates here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=9358.1)
EDITED: 27 Aug 2019 by BEMFARMER
9476.27 In reply to 9476.25
I get the same error message.
I'm on macOS....Are you?
9476.28 In reply to 9476.25
Hi Pilou, if you push the "Report" button does it generate a crash report file? That will be a file named moi_report1.zip . If you get one of those please e-mail it to me at moi@moi3d.com and I'll take a look.
9476.29 In reply to 9476.28
Michael,
When I press "Report" button the error dialog box disappears & immediately reappears but does not generate an error report. Clicking again does the same...& does so for a dozen more clicks.
If then the .nod is STOPped & RUN again (or link to OUTPUT is broken & reconnected) the error
message does not appear.
As I said before, I'm on a Mac.
9476.30 In reply to 9476.29
Hi James, yes sorry the assert crash dump mechanism is not enabled for the Mac version.
I am on PC so maybe I will can send the Repport error! :)
On what folder exit must be this Repport error ? (seems it's a multiple repport )
EDITED: 27 Aug 2019 by PILOU
Added http://moiscript.weebly.com/node.html
Tips
Use the TAB key for validate numeric imput!
More easy than the Enter Key : automatically goes to the next case!
Some colors Nodes can have several "Start" : Light Green and Violet!
​Same multiple Targets are not allowed!
PS Node Star has no word "Out" !
9476.34 In reply to 9476.32
Hi Pilou, it would usually be in your temp folder, from the start menu type %temp% and push enter.
9476.35 In reply to 9476.34
Alas seems the "special" report when I press it from these particular Nodes gives nothing in this temp folder !...
9476.36 In reply to 9476.35
Hi Pilou, does everything go ok if you use "Ignore all" ? The next release will have these warnings (called "Release mode asserts") turned off.
9476.37 In reply to 9476.36
Yes all is ok when I press "Ignore" all :) but also can totally exit from MOi without any warning! :) (but not total crashe just Moi)
I believe that rude exit happend when in these particular Nodes above for the no native node function "Fillets" has bad range for the volume considered!
Added
Tips
The fictitious "radius" of the Circular Array is made by difference of the position of the selected objects and the position of the requested axis! (here XYZ = 0,0,0 and XY = 2,2,0)
Will be added of course :)
done! :) http://moiscript.weebly.com/biblio-elephant.html
All ELEPHANT by Max Smirnov is actually based on this Litegraph ! https://github.com/jagenjo/litegraph.js by Jagenjo
We can use it "ON Line" http://tamats.com/projects/litegraph/demo/
Funny it has used an image of me for illustrate its genious tool! :)
https://github.com/jagenjo/litegraph.js/blob/master/imgs/elephant.gif
Show messages:  1-19  20-39  40-59  60-79  80-99  …  500-503
