Elephant Repository
 1-17  …  158-177  178-197  198-217  218-237  238-257  …  498-503
I am perplex about what exactly do Concat ? (add, associate, Union, Merge... ??? )
Forgotten to make ObjToArray Node
but this yet made can make the trick ! :)
ObjToArray Node (English French)
http://moiscript.weebly.com/objects.html
9476.200 In reply to 9476.198
Hello Pilou,
concat joins Arrays together. e.g.:
numarray 1: 0;2;4;6
numarray 2; 1;2;3;4
concat result 0;2;4;6;1;2;3;4
A nice day to all
Karsten
9476.201 In reply to 9476.200
Ok will study that :)
else
Random Node (English French)
http://moiscript.weebly.com/basic.html
Concat Node (English French) Thanks to Karsten ;)
Hum hum ... am I right? So that I made above is not totally adequate! :)
The ObjtoArray don't change all the OutPut...
I miss another important concept! :)
9476.205 In reply to 9476.204
9476.206 In reply to 9476.205
... (always 2 separated curves selected)
That i find difficult is to pass from a color link to another color link...so useful is the general screen of nodes...
Not yet found the trick...i have now only one point against a complete curve(s) wanted! :)
...or more simple how to obtain Points from a curve selected ? Clone To Pts seems a good candidate but...
Ok I find "how to obtain Points from a curve selected" but it's not inside the Native Nodes! :(
...and always not that i want: result of the join of something coming from the pinky "array" here more than one point (with the native nodes)2 curves from the
or better the rescue of the 2 curves from the Concat of the pinky "array" (always with the natives nodes)
EDITED: 20 Sep 2019 by PILOU
Extract Node (English French)
Does it possible to Show Hide the Grid of the NodeEditor ?
Interp Node ( English French)
The ultima Native last is the "Quartz" Node : i suppose that is a timer but i have not many ideas for use it! :)
If you have a little example ? That will be fine! :)
The next one "Not Native Node" will maybe a little more difficult for me! :)
I would probably need some big help from the creators!
But before to begin this monstruous part i will make some fun training with the natives ones for some relaxing! :)
9476.212 In reply to 9476.208
re: Show/Hide grid of nodeeditor.
Maybe make a white on white grid version of nodeeditor based upon James's alternate color scheme.
This would appear grid-less?
Grid-less color scheme could be assigned a hotkey, and .nod program opened in it?
Could grid colors be changed in an existing/open node canvas, with some added code?
When moving nodes, the nodes have a "snap to nearest grid" feature.
9476.213 In reply to 9476.210
Small example of Quartz node
EDITED: 17 Jan 2021 by WAYNEHILL5202
9476.214 In reply to 9476.212
@Bem I have believed seen somewhere that we can Show / Hide Grid but maybe i have dreamed :)
9476.215 In reply to 9476.213
@WayneHill Many thanks...Bravo! I can now finish my Native Nodes Section!
Excellent! I see the potential! Perfect for animation! ;)
As you can see i didn't made many efforts! Copy Move your original Object
Changed Tic-Tac to Cycled and changed "Value" parameters! :)
Don't find what is this Const ??? It don't appears in the Quartz Info Pannel ???
Not a problem but... :)
The last of the Elephant Native Nodes!
You can find all that here ! http://moiscript.weebly.com/biblio-elephant.html In English! ;) and of course in French also! :)
I will make a little break for use them for the fun before to start the Extention Nodes section! :D
So the Quartz Node : a funny one! Thanks to Waynehill!
Show messages:  1-17  …  138-157  158-177  178-197  198-217  218-237  238-257  258-277  …  498-503
