Elephant Repository
 1-18  …  139-158  159-178  179-198  199-218  219-238  …  499-503
9476.179 In reply to 9476.178
Alternatively use objects2/scaleUVW. See below
9476.180 In reply to 9476.179
@ James Yep ...but I am for the moment only on the Native Nodes! :)
Your help will be of course needed for the extention Nodes...when I will finished the Native part!
"Out" of JitterPts seems gives bad link...
Finally found JitterPts and the scale inside! :)
JitterPts Node (English french)
http://moiscript.weebly.com/points-e.html
Now have one Star figure on the screen during the animation is another story...
surelly restrain the Array Point...Yes it is! :)
EDITED: 15 Sep 2019 by PILOU
Less esoteric example of the CloneToPts node :)
TransformPts Node (English French) rest MathPts in this section! :)
More precision about TextPts Node (Don't know if there are more than 6 parameters ?
If for the normal Math Node I can understand where put some formulas, I am more perplex for the MathPts Node! :)
I need some examples for unblock the situation! :)
9476.187 In reply to 9476.186
The X, Y, and Z can be functions of u and v.
So X = sin(u) would be one example. Y = cos(v), Z = sqrt(something)...
Or more complex equations.
Check out the Macro's, which are likely from James:
mobius, offsetGrid, sineSurf, waveSurf, quadSpheres.
It would be nice to find a really cool example.
Maybe a curvy surface in 3d...
EDITED: 16 Sep 2019 by BEMFARMER
9476.188 In reply to 9476.186
Here is an enneper example by James, posted by Pilou :-)
https://moi3d.com/forum/index.php?webtag=MOI&msg=6521.37
James link to the nod file EnneperScaling.nod:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6521.34
Note the complex formulas.
I think this one is an excellent example.
A surface in formed in 3d space.
The iso linecurves can be viewed with the MoI iso command.
9476.189 In reply to 9476.188
Many Thx! Ok All is clear now! :)
Just a little last question : does it possible to increase the size of the Info Pannel? (seems not)
because biggest formulas are truncated at the screen!
EDITED: 17 Sep 2019 by PILOU
MathPts Node (English French) The Pilou Surface :D
That concludes the "Native Points" Section! Just rest now the "native Basic section"...the cherry on the cake! :)
And exported when you find a cool 3D model inside this infinity of possibilities! :)
Length Node (English French)
Missing of training :)
Wanted to draw a simple sinusoïd with the Basic / Math (not with the Point / Math)
Not yet found an elegant solution!
Progression Node (English French)
http://moiscript.weebly.com/basic.html
EDITED: 18 Sep 2019 by PILOU
9476.194 In reply to 9476.192
Hello Pilou,
You need the second coordinate. Make points and use curve:-)
Have a nice day
Karsten
EDITED: 18 Sep 2019 by KMRQUS
9476.195 In reply to 9476.194
@ karsten
Very elegant and the trick was the big conceptual paradigma "Progression Node" that I totally missed!
and Bravo only use the Native Nodes!
and less intimidating than this one!
So I can make the "Math" node now after study in depth for no deviant art! :)
Math Node (English French) Many Thanks to Karsten!
I am perplex about what exactly do Concat ? (add, associate, Union, Merge... ??? )
Show messages:  1-18  …  119-138  139-158  159-178  179-198  199-218  219-238  239-258  …  499-503
