Elephant Repository
 1-12  …  133-152  153-172  173-192  193-212  213-232  …  493-503
9476.173 In reply to 9476.168
So MathPts can make a u,v network of a surface in 3d space by feeding its output into two ConvertPts, one with Curve U output, and one with Curve V output,
based upon a mathematical formula with Javascript math, which includes typical math such as sines, cosines, *, +, etc.
Feeding Curve U and Curve V into a network should make a surface.
9476.174 In reply to 9476.172
James, your light color scheme look very good. Will you be making it available?
9476.175 In reply to 9476.174
Brian
I'm glad you like my NE mod UI. I find it more legible.
I have attached my nodeEditor folder. It also includes my alterations to node labelling and titling of many of the nodes for logical consistency and removal of redundant info. This does not in any way impact on the operation of NE, or the opening & running of existing .nod files; it is purely cosmetic. Nevertheless clarity & consistency are, IMHO paramount UI/UX considerations.
I encourage you to give it a go....however if you only want to change the colour scheme, just replace main.js & colors.js in the core folder.
Have a great weekend
EDITED: 14 Sep 2019 by JFH
9476.176 In reply to 9476.175
Thank you James, your colors now replace the "dark" theme.
The previous "light" theme is also still available with appropriate alternate hotkeys.
9476.177 In reply to 9476.172
@James ...something like this! Target of the scaled volume(s) has the same x,y,z than the start one!
because all your examples used a figure who have yet a "center" inside their definitions so more easy to manage! :)
There is not such thing inside a simple complex volume(s) selection except maybe the Bounding Box...but I wish a specific x,y,z point :)
(maybe your last example will give me some ideas ...
Maybe JitterPts Node who has a Scale item inside can also make something...
other thing : Why colors of links have changed in your new personnal design UI of Node Editor?
@Bem ... yes i see the theory but can you put a little example with the nodes Math concretely for see how input formula in a Math node! :)
EDITED: 15 Sep 2019 by PILOU
Ok find my wished Scale! :)
Start Object is selected at the good X,Y,Z position! (1,2,3)
The trick was to put 1,2,3 inside the Node Point (but even seem the "Frame" works only with 2 x,y positions ? )
and 1,2,3 inside the Move Node! :)
so some relatively easy :)
9476.179 In reply to 9476.178
Alternatively use objects2/scaleUVW. See below
9476.180 In reply to 9476.179
@ James Yep ...but I am for the moment only on the Native Nodes! :)
Your help will be of course needed for the extention Nodes...when I will finished the Native part!
"Out" of JitterPts seems gives bad link...
Finally found JitterPts and the scale inside! :)
JitterPts Node (English french)
http://moiscript.weebly.com/points-e.html
Now have one Star figure on the screen during the animation is another story...
surelly restrain the Array Point...Yes it is! :)
Less esoteric example of the CloneToPts node :)
TransformPts Node (English French) rest MathPts in this section! :)
More precision about TextPts Node (Don't know if there are more than 6 parameters ?
If for the normal Math Node I can understand where put some formulas, I am more perplex for the MathPts Node! :)
I need some examples for unblock the situation! :)
9476.187 In reply to 9476.186
The X, Y, and Z can be functions of u and v.
So X = sin(u) would be one example. Y = cos(v), Z = sqrt(something)...
Or more complex equations.
Check out the Macro's, which are likely from James:
mobius, offsetGrid, sineSurf, waveSurf, quadSpheres.
It would be nice to find a really cool example.
Maybe a curvy surface in 3d...
EDITED: 16 Sep 2019 by BEMFARMER
9476.188 In reply to 9476.186
Here is an enneper example by James, posted by Pilou :-)
https://moi3d.com/forum/index.php?webtag=MOI&msg=6521.37
James link to the nod file EnneperScaling.nod:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6521.34
Note the complex formulas.
I think this one is an excellent example.
A surface in formed in 3d space.
The iso linecurves can be viewed with the MoI iso command.
9476.189 In reply to 9476.188
Many Thx! Ok All is clear now! :)
Just a little last question : does it possible to increase the size of the Info Pannel? (seems not)
because biggest formulas are truncated at the screen!
EDITED: 17 Sep 2019 by PILOU
MathPts Node (English French) The Pilou Surface :D
That concludes the "Native Points" Section! Just rest now the "native Basic section"...the cherry on the cake! :)
And exported when you find a cool 3D model inside this infinity of possibilities! :)
Length Node (English French)
Missing of training :)
Wanted to draw a simple sinusoïd with the Basic / Math (not with the Point / Math)
Not yet found an elegant solution!
Show messages:  1-12  …  113-132  133-152  153-172  173-192  193-212  213-232  233-252  …  493-503
