| Hi Pilou,It does seem like ScalePts node is not working.  Maybe it needs different inputs?
 I suspect that the problem is that the Pink Dots represent a pointarray class, which is much more than just raw points.
 Max wrote: "point/frame array", and also "One more node added - TextArray
 It converts text data to pointarray. For each point can be set upto six values: x, y, z, x-rotation angle, y-rotation angle, z-rotation angle."
 Karsten posted some explanations, related to his splitPts node and his PointExt node.
 7777.675
 9189.16
 9189.20 "at first - yes it's a frame description:
 x,y,z, Euler-angles (x,y,z by using rotation order x,y,z), scale mostly 1 (useful for some programming - can be used as scale factor or for transformation proposes (homogenous coordinates)."
 7777.1336
 Puzzled - Brian
 The pSize (scale) input is Karsten's PointExt node does not seem to work either?
