Elephant Repository
 1-17  …  98-117  118-137  138-157  158-177  178-197  …  498-503
Twist Node ( English French)
http://moiscript.weebly.com/transform.html
Flow Node (English French)
Circular Array Node (English French)
I have some troubles with Orient Node!
Seems no automatic "orientation"! ???
9476.142 In reply to 9476.141
Hi Pilou, I think you'll need to supply a coordinate frame at your desired position instead of just a point.
9476.143 In reply to 9476.142
Ok but i don't see difference from a simple "Move" + "Rotate Point" against "Orient" + "Rotate Point" ?
And I must find something who give the exact orientation because with sliders there is not "snap" :)
Something like a "given face" gives the orientation of it...or...
And other thing : does the "Native functions" can work only from them ? So making "Orient" just with them...
EDITED: 10 Sep 2019 by PILOU
9476.144 In reply to 9476.143
Well the regular Transform > Orient command is indeed a combination of movement plus rotation. With something that might have more complex rotations orient could be more convenient. Like if you are applying some kind of repeated rotation on a coordinate frame Orient can take that coordinate frame directly.
Sorry, I don't understand this part.
9476.145 In reply to 9476.144
Actually there are 2 parts of nodes : native and extensions
So i will to know for example if native Orient can be used only with native nodes for obtain an exact results !
Because it was created before the extensions!
Problem for the moment i can't find a simple trick for have the good result!
Difficulties (for me) is transform a selection in a "frame" usable! :)
Orient something following a line or a face...surely trivial but...
9476.146 In reply to 9476.145
Sorry, I don't know the answer to this.
For a curve you could call evaluateTangent on it to get its tangent direction and use that as the z axis of your frame, and you would then need to make the x and y axis directions by doing some vector math like using crossproduct.
If a curve is planar, (crv.isPlanar == true) then you can get the frame of its plane by crv.planarFrame
The next v4 beta will also has that for faces as well.
9476.147 In reply to 9476.146
yes but seems all that is in the "extention" parts!
So stay in stand by till I finish the "native" part :)
Section POINTS
http://moiscript.weebly.com/points-e.html
Points Node (English French) not sure of what is this! (from where comes the first curve of points? A simple line of ... by default because I have nothing selected! :)
InterpPts Node (English French)
SpherePts Node ( English French)
PolygonPts Node ( English French )
MovePts Nodes (English French)
RotatePts Node (English French)
Added a short synthetic (i wish:) explanation of each yet made Point Node section! :) (English French)
EDITED: 12 Sep 2019 by PILOU
I am perplex about the ScalePts Node!
Don't work as supposed! (like the previous nodes)
I believe that Points would move away but nothing more than the still start position! ???
(there is nothing drawn on the rest of the screen)
I must miss something!
2 points are selected at the start!
TextPts Node (English) surrely more possiblities but this is working! :)
Clone To Points ( English French) ...and better understand of what was the "Points" Node! (a simple variable 3D Array! :)
Input Selection inside an Array Base(s) of Points
Show messages:  1-17  …  78-97  98-117  118-137  138-157  158-177  178-197  198-217  …  498-503
