Elephant Repository
 1-5  …  66-85  86-105  106-125  126-145  146-165  …  486-503
ObjToArray is totally mysterious for me!
And surrely ConvertPoint! :)
(Selected (0) is normal I made the ScreenShot between 2 tests )
How Extract all from a selection in one pass ?
EDITED: 7 Sep 2019 by PILOU
9476.107 In reply to 9476.106
Selected > ObjtoArray > extractPts > Output
9476.108 In reply to 9476.106
PinkDot represent pointarray class, and contain many properties, including "raw" points, e.g.(x,y,z), AND frames and scales(?) and angles...
GoldDot points are MoI's geometry form of points, which can be added to the geometry database and displayed in MoI. (Object Lists)
GoldDot points can have styles, names, etc.
EDITED: 13 Sep 2019 by BEMFARMER
<<Selected> ObjtoArray > extractPts > Output
I have a cube selected
Not yet working! (square orange) and not sure that takes all points...(maybe also i don't use good nodes after the Extract)
9476.110 In reply to 9476.109
This is working. Maybe right click on Selected and Update. The extractPts is in the Objects2 node
EDITED: 17 Jan 2021 by WAYNEHILL5202
9476.111 In reply to 9476.110
New test only one point (before reading your last post)
Ah OK Cool! you pass not by the "Array" :)
So what is the "Pink Array" of the "ObjTo Array" ?
Just a little Thing : The "ExtractPts" is not in the Native Nodes!!!
I am only on the Native Nodes for the moment! ;)
So maybe that is not possible with only Native Nodes ?
And always want to know what is exactly the Pink "Array" of the Native Node "ObjToArray" :)
More easy :)
Node Loft (English French)
http://moiscript.weebly.com/construct.html
Node Sweep (English French)
Node Extrude ( English French)
New little blockage! I stay on a Flat land! :)
Surely trivial but what is the "Frame" inside the Revolve Node and how to use it?
Of course I can rotate first my Profil... but i want to know the use of this mysterious "Frame"! :)
More easy :)
Node Boolean Diff (English French)
9476.118 In reply to 9476.116
Hi Pilou, a frame is an origin point and 3 direction vectors which together defines a 3D coordinate system, like this:
Probably your case there will use the z axis of the frame as the axis of revolution.
9476.119 In reply to 9476.118
Cool! Seems that but there is a direct exit from MOi! :) (without report! )
In general when slider go toward 0 (even 0 is not touched) - this is the same thing for any of axis chosen!
Ps The file ".3dm" saved don't appear on the list of last saved ! ??
I have yet 15 last saved files in this list (does exist a maxi number)
Saved is done before launch the Node!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/speed_exit.3dm
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/speed_exit.nod
EDITED: 8 Sep 2019 by PILOU
9476.120 In reply to 9476.119
Hi Pilou, since the node editor uses GeometryFactory::calculate() it runs the factory calculation inside MoI.exe instead of running it in the separate moi_commandprocessor.exe process as will happen when running the regular Revolve command. As a side effect of this there are some kinds of bugs that you can encounter with the node editor that get screened out with the regular commands because if moi_commandprocessor.exe crashes the MoI.exe process just keeps going ok.
In this case the bug is the revolve factory will crash if given a 0 (or perhaps very small) angle value. This could be tuned up in the Revolve node to not try and do the revolve if the angle is very small. Something like: if ( Math.abs(angle) < 0.01 ) return;
I've updated the revolve factory itself to do that as well so in the next release that shouldn't happen even with the current revolve node.
Anyway :)
Node Intersection (English French)
9476.122 In reply to 9476.119
The "recent files" list is written to moi.ini when MoI closes down but if it crashes then the normal shutdown processing does not happen.
The number of recent files that are displayed can be adjusted in moi.ini :
[UI]
MaxNumRecentFiles=15
9476.123 In reply to 9476.122
Thx for the Infos!
Node Union (English French)
About the Revolve function : I try to add the "if ( Math.abs(angle) < 0.01 ) return;" inside the construct.js file of the nodeeditor
but as I don't know where exactly to add it i have for the moment some errors... :)
PS about the Node editor for the V3 I have only a "White screen Window"
I have tryed
​moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ) on the prog itself
​moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); on the "application data"
no success
What is the number of the version of NodeEditor working for the V3?
Show messages:  1-5  …  46-65  66-85  86-105  106-125  126-145  146-165  166-185  …  486-503
