Reverse vieport views
All  1  2-13
9473.2 In reply to 9473.1
9473.3 In reply to 9473.2
Hi Marco, that was a fast reply:)
Ron
9473.4 In reply to 9473.3
Hi Ron, also just in case you didn't know you can get a reversed view without using a script - if you click a second time on a viewport tab in the bottom command bar it will toggle back and forth between the regular view and the reversed one.
9473.5 In reply to 9473.4
Hi Michael. I don't think any of these extra features are mentioned in the manual. It's a little like a software easter egg you discover over time:)
Ron
9473.6 In reply to 9473.5
Hi Ron, actually it's mentioned on the very first page of the manual! :)
http://moi3d.com/3.0/docs/moi_introduction.htm
quote:
2. Viewport configuration tabs. This controls whether the viewport area shows the split view or only a large single view. You can switch some views to the reverse direction by clicking on their tab a second time. For example, a second click on the Top tab will flip it to a Bottom view.
However, subtle things like this that don't have an immediate visual cue are pretty difficult to absorb on an initial pass through the manual. It's something that will "stick" more after you've done more things and actually wanted to use a reversed view for something.
You will probably find a lot of little easter-egg like things if you run through the manual again after you've spent more time in MoI.
Or you ask a question here and learn about it that way, that's totally fine. I mean don't get me wrong it's good for people to look stuff up in the manual too but for some kinds of things it's going to be harder to immediately know where you would look.
That's kind of a design goal for MoI's UI in general, that as you gain more experience you can get more things out of the same UI without it being all blasted in your face all at once when you first start out.
9473.7 In reply to 9473.6
Ooops, Michael I,ve read through this a dozen times and never seen that. Like you say, there is a lot to take in!
Ron
9473.8
I also found some small but smart features in MoI throughout the time. I should definitely go through the manual again :)
9473.9
This script reverses which ever view the mouse is over except 3d
script:moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
another good script to use with the mouse view becomes the full screen
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
9473.10
Michael, I think it would be great shortcut if (when having split view) right-click on viewport (top/bottom, right/left, back/front) would cause just flip that viewport view.
I use split view basically all the time and often switch between views as mentioned.
Now I have to click 3 times to switch top to bottom or others.
I know that it saves just 2 clicks and like 0.5 second (each time), but screen flashing is also quite unpleasant when clicking.
Or if you can let me know of other shortcut to achieve this it would be great.
EDIT:
I just found script for that. But built in function would be great and I think it wouldn't take much time to integrate as native.
Regards,
Juraj
9473.11 In reply to 9473.10
Hi Mr. Yuri,
Right click in a viewport is already used for a different function than that - when you are not in a command a right click in a viewport will repeat the last command and if you are in a command it is a shortcut for the "Done" button.
EDIT: Oops sorry I thought you meant a right click inside the viewport itself but I think I figured out you mean a right click on the view tab control. That should be fine for the default behavior.
EDITED: 25 Aug 2019 by MICHAEL GIBSON
9473.12 In reply to 9473.10
Hi Mr. Yuri, please try replacing your MoI v4's ui\ViewTabs.htm file with the attached version. With this version if you right click on the Top/Front/Right tabs it will reverse the view but not activate the tab.
I guess this would be ok for default behavior.
EDIT: updated behavior slightly - when on "Split" view mode the right click on Top/Front/Right will reverse the view and stay in Split mode. When in other than Split mode it reverses and also activates the clicked on tab.
EDITED: 26 Aug 2019 by MICHAEL GIBSON
9473.13
Michael,
simply WOW!
I am very very happy with your support.
Works like a charm.
Sorry for not making my request clear enough straight away.
Juraj
Show messages: All  1  2-13
