Reverse vieport views
All  1-10  11-13
9473.11 In reply to 9473.10
Hi Mr. Yuri,
> Michael, I think it would be great shortcut if (when having split view) right-click on viewport
> (top/bottom, right/left, back/front) would cause just flip that viewport view.
Right click in a viewport is already used for a different function than that - when you are not in a command a right click in a viewport will repeat the last command and if you are in a command it is a shortcut for the "Done" button.
EDIT: Oops sorry I thought you meant a right click inside the viewport itself but I think I figured out you mean a right click on the view tab control. That should be fine for the default behavior.
EDITED: 25 Aug 2019 by MICHAEL GIBSON
9473.12 In reply to 9473.10
Hi Mr. Yuri, please try replacing your MoI v4's ui\ViewTabs.htm file with the attached version. With this version if you right click on the Top/Front/Right tabs it will reverse the view but not activate the tab.
I guess this would be ok for default behavior.
EDIT: updated behavior slightly - when on "Split" view mode the right click on Top/Front/Right will reverse the view and stay in Split mode. When in other than Split mode it reverses and also activates the clicked on tab.
EDITED: 26 Aug 2019 by MICHAEL GIBSON
9473.13
Michael,
simply WOW!
I am very very happy with your support.
Works like a charm.
Sorry for not making my request clear enough straight away.
Juraj
Show messages: All  1-10  11-13
