Sweep with Draft or Loft with Guide
All  1-2  3-5
9470.3 In reply to 9470.1
Hi Don, yes the sweep command in Moi can do that. However, you will need to prepare your curves a bit more before doing the sweep. Your path curve is currently in multiple individual separate curves and sweep will be expecting for the path to be just one single curve. So you would need to use the Edit > Join command to glue those curves together into a single connected piece before using it in Sweep.
Additionally a couple of your pieces don't quite touch each other end to end so that also needs to be adjusted a bit.
Try with the attached version:
9470.4 In reply to 9470.3
Thanks Michael. I will have a closer look. It's been a while since I used MoI, so must have forgotten what I probably know before.
_________________________
Don Cheke
Visit: Textual Creations
9470.5 In reply to 9470.2
Thanks Brian, Sorry, I had missed your post.
Don Cheke
Show messages: All  1-2  3-5
