Questions about purchasing
9468.1
Hello,Michael. I want to know if I bought it, can I use it with a laptop in school and a desktop computer at home? If my computer is broken, the serial number can continue to be used? Is a serial number common to PC and MAC? In short, what are the restrictions on the serial number? Sorry, I don’t know anything.
9468.2 In reply to 9468.1
Hi weiji, you can install the same one purchased MoI license on any number of machines you use, including across Windows and Mac, just as long as it is only actively launched and running on one of those installs at a time. You would only need a separate license for another machine if you wanted someone else to be running it there the same time as you.
You don't need to do anything special to set up the multiple installs, you just use the same installer and license key on each one. MoI does not bind itself to only install on one hardware signature, or require any "activation".
Yes.
Yes you can just put it on a new machine, you don't have to remove it from the old machine.
Yes Windows and Mac use the same license keys.
Just that you don't give it to someone else. It's meant to be used by you and you can use it on whatever machines you use. It does do a check on the local area network to see if any other computers are actively running with the same license key, you will get a "license in use" error in that case. Just exit MoI (close the running program, not uninstall) from the other machine.
9468.3
Hello I am a 3d student and I would have liked to know what are the differences in content and rights between an educational license and a conventional license. thank you in advance
9468.4 In reply to 9468.3
Hi Maxime, there are no restrictions on what content you can produce with the educational license, you can use it for any kind of work including commercial work.
The only difference between a regular full license and the educational one is the educational one can't be resold.
