Shortcut to drawing guidelines?
All  1-3  4-5
Spirit of the Guide Helper Lines is to work with only the Function called! ;)
Call any function
Click without relase, move, release
---can be make before the first click of the function, after the first click of the function, before the last click of the function---
Don't forget that you can press 1 second on the little "white mark" for have more functions of the Helper Line itself
(Right or Left click)
Move - Re Orient - Rotate - Division Snap - Projection Next Point
Of course you can use the plugin for persistant Guide Lines but no need with some training! ;)
EDITED: 31 Jul 2019 by PILOU
9456.5 In reply to 9456.3
No problem. I will carry on with things as they are. It was just a thought. I do already use the K and Ctrl K shortcuts to keep and delete construction/guide lines when needed.
M
Show messages: All  1-3  4-5
