Moi 3d v4 and rocket 3f
9451.1
Does moi 3d v4 support the rocket 3f “sand to moi” script? keep the crease effect ? I know moi3d v3 support this cript but no crease.
If it can, then this workflow will be great. (rocket 3f +moi 3d----subd+nurbs);
(My English is not good, I don't know if you can understand it.)
9451.2 In reply to 9451.1
Before I remember if it's possible, you can export your creased object in OBJ format from Rocket 3F and reload it inside MOi by SubDivision / Create from a file...you will have your creased edges!
9451.3 In reply to 9451.1
Hi weiji, sorry I'm pretty sure it will work the same as v3. I don't think edge weighting will come over.
OBJ files do not have any mechanism in them to support edge weights.
Script don't keeps the creases...
But the method writed above keeps the crease! ;)
New version 1.7.1 with always a free version possible! (Direct Bridge with Moi3D in the 2 ways)
https://rocket3f.com
9451.6 In reply to 9451.5
Great software Rocket3F.
Very underrated but a great software.
I had a little problem export Import Moi <--> Rocket 3F but with reloading last version of Bridge !
All is perfect !
So more easy !
In Rocket Select something Subdivided or Not : Press the Icon "MOI" (or CTRL + Alt + A)
In Moi : Select Something Subdivided or Not : CTRL + Alt + A
That all!
EDITED: 15 May 2020 by PILOU
9451.8 In reply to 9451.5
I think it is Rocket3F v 1.7.3:
https://www.rocket3f.com/kunena/updates/1001-version-1-7-3#5408
regards
Ken
With the last Bridges all works like a charm!
Just Press Ctrl + ALT + A when you are in MOI
Just press the Moi Button when you are in Rocket 3F!
https://www.rocket3f.com/downloads/Rocket3F_Portable_1.8.rar
Portable version of this free retro futurist modeler! ;)
9451.11 In reply to 9451.10
Hallo Frenchy,
I unpacked it, but it won´t run.
9451.12 In reply to 9451.11
I believe that you must free registered!
