Strange experience with MoI v4 beta Feb-27-2019
All  1-4  5-12
9443.5 In reply to 9443.4
I can't reproduce it on Mojave 10.14.5. Is OK.
9443.6 In reply to 9443.5
Thanks Finema, must have been fixed sometime after 10.14.0 . I think I've got a fix for it anyway though which should hopefully be less likely to get messed up.
9443.7 In reply to 9443.1
Hmm well my new way does not seem to work well on older OS versions so maybe I shouldn't mess with this.
Martin, are you on 10.14.5 or an older version of Mojave then that?
9443.8 In reply to 9443.7
I also use OS X 10.14.5
System Version: macOS 10.14.5 (18F132)
Kernel Version: Darwin 18.6.0
Hi Finema,
just to be extra clear the option dialog buttons really work in FULLSCREEN MODE?
-Martin
EDITED: 26 Jul 2019 by MARTIN3D
9443.9 In reply to 9443.8
Hi Martin
You are right > don't work in fullscreen mode
9443.10 In reply to 9443.8
Hi Martin & Finema - I've got a fix for this problem where the sub dialogs on the Options window weren't showing in full screen mode on Mojave. So it should be fixed for the next v4 beta. I was able to simplify the dialog level management quite a bit so hopefully it won't be likely to get broken again.
Thanks for reporting it!
9443.11 In reply to 9443.10
Thanks Michael !
9443.12 In reply to 9443.10
Thank you!
Show messages: All  1-4  5-12
