Strange experience with MoI v4 beta Feb-27-2019
All  1  2-12
9443.2 In reply to 9443.1
Hi Martin, hmm that's pretty strange. Is it possible that on the button pushes where nothing happens that the dialog is being shown underneath the Options dialog? I mean like for example when you push "Lighting options" and nothing happens, if you then move the Options dialog to the side a ways are you able to see that the dialog is underneath it?
Do you possibly have any kind of custom window management extensions set up on your system?
9443.3 In reply to 9443.2
no the windows are not shown underneath the Options dialog and I have no custom window management extensions installed.
But when I just tried to look if the windows are maybe behind the MoI program window I noticed that I used MoI in Full Screen Mode (Green button) which I normally don't do. I switched to normal window mode and the options dialog worked as expected. It's only in Full Screen Mode that the buttons do not work.
Now that I know that it is no big deal as I generally prefer to work in normal window mode.
- Martin
EDITED: 25 Jul 2019 by MARTIN3D
9443.4 In reply to 9443.3
Hi Martin, I am able to repeat that over here. It looks like they are actually behind the options dialog but they are attached to it and move with it so you can't uncover it. It does not seem to happen on High Sierra so I'd guess it's probably a bug in Mojave but I'll investigate what I can do to avoid it. Thanks for reporting it!
9443.5 In reply to 9443.4
I can't reproduce it on Mojave 10.14.5. Is OK.
9443.6 In reply to 9443.5
Thanks Finema, must have been fixed sometime after 10.14.0 . I think I've got a fix for it anyway though which should hopefully be less likely to get messed up.
9443.7 In reply to 9443.1
Hmm well my new way does not seem to work well on older OS versions so maybe I shouldn't mess with this.
Martin, are you on 10.14.5 or an older version of Mojave then that?
9443.8 In reply to 9443.7
I also use OS X 10.14.5
System Version: macOS 10.14.5 (18F132)
Kernel Version: Darwin 18.6.0
Hi Finema,
just to be extra clear the option dialog buttons really work in FULLSCREEN MODE?
-Martin
EDITED: 26 Jul 2019 by MARTIN3D
9443.9 In reply to 9443.8
Hi Martin
You are right > don't work in fullscreen mode
9443.10 In reply to 9443.8
Hi Martin & Finema - I've got a fix for this problem where the sub dialogs on the Options window weren't showing in full screen mode on Mojave. So it should be fixed for the next v4 beta. I was able to simplify the dialog level management quite a bit so hopefully it won't be likely to get broken again.
9443.11 In reply to 9443.10
Thanks Michael !
9443.12 In reply to 9443.10
Thank you!
Show messages: All  1  2-12
