Rhino 6 to Moi?
All  1-3  4-16
9442.4 In reply to 9442.3
Hi Chris, well you'll probably need to reconstruct it to get a proper model in MoI - in its current form it's all made up of a bunch of triangle facets instead of having any curved surfaces in it at all. The areas that sort of look curved are not really, they just have a bunch more little flat facets there.
You could use the MeshToNurb command in Rhino to convert each triangle into a trimmed NURBS surface, which would then import into MoI but that will make a very low quality model so there isn't much you'll be able to do with it other than kind of use it as a guide.
9442.5 In reply to 9442.3
I can suggest my workflow, just discovered some day ago, export from Rhino to DXF mesh or use Blender 3D to export your mesh into DXF format with default exporter setup, and then import into gCAD3d and export your file to Step.
There is an other method I know but is with FreeCAD but for that there are some tutorial in the WEB
http://gcad3d.org/
https://www.blender.org/
Maybe another one will be DXF --> OBJ above Blender method --> OBJ --> Instantmesh(free)more easy than Blender so quadmesh -->export OBJ -->
import OBJ inside MOi 4 beta by Max Smirnov function or Subdivision from a file by the native function of moi v4 beta
https://github.com/wjakob/instant-meshes
http://moi.maxsm.net/files/scripts/ImportObj.v.1.5.2015.09.10.zip
EDITED: 25 Jul 2019 by PILOU
9442.7 In reply to 9442.6
And how do you apply this? - https://github.com/wjakob/instant-meshes
From Rhino?
9442.8 In reply to 9442.7
Hi mk, that looks like a standalone program that can load .obj or .ply polygon mesh files. So to use it from Rhino you would export out to a polygon mesh .obj file and then use "Open mesh" in that program to load it in.
9442.9 In reply to 9442.8
But, is there another way to use it as a standalone program without Rhino?
That SubD --> Create from .obj file command in MoI 4.0 Beta is somehow working but the .obj file imported directly from for instance ArchiCad like in my case, contains partly triangulated mesh and some parts as solids.
So, I thought that hopefully there is a brilliant idea to prepare that .obj mesh before bringing it to MoI by SubD --> Create procedure, as it doesn't require Rhino.
Marek
9442.10 In reply to 9442.9
Hi Marek,
Yes, I'd think that it should work with .obj files generated by any program, not just ones exported from Rhino.
What happens when you try to open your .obj file from ArchiCad into it?
9442.11 In reply to 9442.10
"..What happens when you try to open your .obj file from ArchiCad into it?"
- As attached.
3D window in ArchiCAD with the original file and then after Max' .obj import and then SubD as well.
One may wonder, why bother if it is OK in ArchiCAD?
- _CVolume2 add-on for weight calculation which I found to be a brilliant thing.
- Marek
EDITED: 10 Aug 2019 by MARKY
Size: 146.6 KB, Downloaded: 48 times, Dimensions: 1522x1166px
Size: 283.3 KB, Downloaded: 51 times, Dimensions: 1467x1310px
Size: 348 KB, Downloaded: 51 times, Dimensions: 1950x1350px
9442.12 In reply to 9442.11
Too bad as I own ArchiCAD v.19, but I think there is native .3dm Open / Export possibility starting from AC v.20.
Well, for that pleasure you have to spend another few thousand euros to upgrade ...
9442.13 In reply to 9442.11
Hi Marek, the type of mesh geometry you show there isn't suitable for sub-d smoothing. A mesh designed for sub-d smoothing should be made up primarily of quads and structured as described at https://www.youtube.com/watch?v=ckOTl2GcS-E .
What you have there is non-subd triangle mesh geometry, so it's not going to work right for using it as a sub-d control cage.
MoI is not designed to work with triangle mesh geometry like that.
If you can export from ArchiCad to .stl format you might try using an STL viewer type program such as https://www.materialise.com/en/software/minimagics , those are likely to have a weight calculator function.
9442.14 In reply to 9442.13
Thank you, as again your willingness to help is the most valuable add-on for MoI.
Yes, that software nicely imports the .stl model but that's it.
Now, it looks to me that the most efficient idea for this is simply to use Excel.
Thanks again,
Marek
9442.15 In reply to 9442.14
There is another way to create a mesh with quads, from one made by triangles, using Blender, import your file in Blender and use the remesh modifier, and raise the level to nine and apply and then export a perfect mesh with quad topology.
below a try done now for this topic. but is bit heavy model, maybe reduce the subdivision with decimate modifier using option unsubdivide but with pair value multiply.
EDITED: 4 Nov 2021 by PAFURIJAZ
9442.16 In reply to 9442.15
Tried that, but Blender (2.8) got inoperable after using Remesh modifier.
Nevertheless, there is a clever add-on in Blender - 3D Print Toolbox giving a Volume and an Area of solids, but I'm not sure about the accuracy of it in regards of real profiles thickness and so on.
Thank you, anyway
Show messages: All  1-3  4-16
