Rhino 6 to Moi?
All  1-13  14-16
9442.14 In reply to 9442.13
Thank you, as again your willingness to help is the most valuable add-on for MoI.
Yes, that software nicely imports the .stl model but that's it.
Now, it looks to me that the most efficient idea for this is simply to use Excel.
Thanks again,
Marek
9442.15 In reply to 9442.14
There is another way to create a mesh with quads, from one made by triangles, using Blender, import your file in Blender and use the remesh modifier, and raise the level to nine and apply and then export a perfect mesh with quad topology.
below a try done now for this topic. but is bit heavy model, maybe reduce the subdivision with decimate modifier using option unsubdivide but with pair value multiply.
EDITED: 4 Nov 2021 by PAFURIJAZ
9442.16 In reply to 9442.15
Tried that, but Blender (2.8) got inoperable after using Remesh modifier.
Nevertheless, there is a clever add-on in Blender - 3D Print Toolbox giving a Volume and an Area of solids, but I'm not sure about the accuracy of it in regards of real profiles thickness and so on.
Thank you, anyway
Show messages: All  1-13  14-16
