X,Y,Z object alignment
All  1-4  5-10
9441.5 In reply to 9441.4
As far as "reproducing" a graphic, with imprecise symmetry such as this,
The drawing has 5 fold symmetry, so by establishing an estimated center point, and about 5 distinct master points, each at a respective "average" distance from the center,
1/5th the graphic can be reproduced with MoI tools, and then circular arrayed. (or use the 5 points with polygon type tools.)
9441.6 In reply to 9441.5
Thank you for helping.
What was used:
Draw Curve, from Moi sidepane.
Selected: Polygon Star, Sides 5, Style Custom.
Then;
Transform, Align, Pick alignment point,
Horizontal center & Vertical center were used.
9441.7 In reply to 9441.6
Hi 3d2cnc, the Transform > Align command uses the center of the object's bounding box as the point to align. That won't do what you need on a star polygon because the top point of it sticks out further than the bottom 2 legs.
So you would instead need to use the Transform > Move command to do the placement, not Transform > Align. Or better yet is to just draw it in the desired place from the start and don't try to use an additional Align on it.
9441.8 In reply to 9441.7
Thank-you, Michael.
The bounding box...of course. Should have known it would simple.
Certainly a Learning curve.
Verified..draw in place.
-Dave
9441.9 In reply to 9441.8
Thank-you Brian.
9441.10 In reply to 9441.9
Hi 3d2cnc,
You should document your procedure, as a method to "distress" graphics to look more natural, and less artificial :-)
Show messages: All  1-4  5-10
