Curve from 2 views?
All  1-4  5-10
9440.5 In reply to 9440.3
Hi Przemas, can you please post the file with the line in it that doesn't work?
Thanks, - Michael
9440.6 In reply to 9440.5
sure, I've uploaded the file and video explanation :) :
https://drive.google.com/file/d/1RF_0phOy2PpiiTgPsIZTSj_sr4kbHJhM/view?usp=sharing
9440.7 In reply to 9440.6
Hi Przemas, so yes currently MoI's "curve from 2 views" only works with 2 planar curves, which does not include lines since a line can be on many different planes instead of just one plane. I've updated this function for the next v4 beta so it will work with lines too. However your particular line curve there is made up of 5 points that squiggle around only very slightly but enough so that MoI doesn't recognize it as a line. But if you make a simple 2 point line there that will then work in the next v4 beta.
Thanks, - Michael
9440.8 In reply to 9440.7
Thx Michael, glad to know it will work with lines in V4 :) . Initially I've used a line, then as it didn't work, I've started experimenting and tried a control point curve (built from points on a line - straight as far as I can tell, but I guess internally, when you go really down with tolerances it might not be - but can't really draw any more precise than software allows me :D ).
9440.9 In reply to 9440.8
Hi Przemas yeah probably the "is it a line" function shouldn't have such a super tight tolerance. But it's kind of a bad time to mess with that right now near the end of the beta period.
9440.10 In reply to 9440.9
totally got it Michael. Stability comes first :) . And if it will work with regular lines it will be more than fine - it is an edge case already :) .
Show messages: All  1-4  5-10
