Distribution(s)
All  1-2  3-10
9435.3 In reply to 9435.2
Yes something like that... https://rawandrendered.com/modularity
From a Camacho image above
If you see the Vertical and horizontal repetitions the inbetween objects are some regular (except the front vertical corner) ...rythmed... but objects itselve are irregular
I want add "variation" of the gap itself...like in the prime number list or purelly randomized . .. ... ..... ....... ........... :)
Maybe the Elephant will be the best solution ... some cursors for Move away/ Bring nearer some objects different or not...for avoid to bricolate in the code! :)
A sort of differential ExplodeMove...a randomized distribution
EDITED: 22 Jul 2019 by PILOU
For simulate different gaps: display random number of objects on their positions from a collection
Node random Obj is existing
not yet exactly that i wish :) the gaps 1 3 1 1 1 2 result must be on each object
9435.5 In reply to 9435.3
Hi Pilou, what about just drawing it how you want it?
9435.6 In reply to 9435.5
Will be easy for few number of objects but not over 10-15 objects and in different directions! :)
I am more confident on the machine!
9435.7 In reply to 9435.6
Hi Pilou, yes maybe something to try with Elephant then?
9435.8 In reply to 9435.7
Objects Selected is existing
Classic Random is existing
Move is existing
Display is existing
Not sure about the "one by one"...and the "loop / return"
9435.9 In reply to 9435.8
Hi Pilou, sorry I don't have enough experience with the node editor to be able to help you with that very well.
9435.10 In reply to 9435.9
No problem i will post on the forum node player! ;)
Show messages: All  1-2  3-10
