Failure message while opening folder with Moi .exe inside
All  1-3  4-9
9416.4
No, I had no adiministration rights. I copied the file from sd card and pasted it on the intern card and from there I could start the installation.
9416.5 In reply to 9416.4
Hi Rudl, but not having admin rights should definitely not result in your whole computer crashing!
Something is going wrong there, some possibilities are a buggy anti-virus program, or a hardware problem like a disk starting to fail or RAM starting to fail.
9416.6 In reply to 9416.5
Yeah, limited rights should not cause a bsod. Just be careful and save your work!
9416.7 In reply to 9416.4
Yeah if your hard drive is pretty old it may be a good idea to get a replacement set up. Or at least make sure you've got important stuff backed up.
9416.8
This is a surface pro 2, which I bought used. But I can give it back. i will buy me a newer one, perhaps a surface book.
9416.9 In reply to 9416.8
Hi Rudl, that may be a good idea to return it, a new machine should not give a blue screen just from opening a folder.
Show messages: All  1-3  4-9
