Drop at level 0
All  1  2-16
9411.2 In reply to 9411.1
Hi moujiik, try the PutOnGround script which you can find here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5427.13
It would not be difficult to make a separate version where you could pick an additional object for the level instead of z=0 like PutOnGround does. What should it do if the other object is not planar though, I guess align it to the minimum z ?
9411.3 In reply to 9411.2
Great! Thank you so much.
I didn't thought of using it with not planar object, but align to the minimum Z is probably the best.
Otherwise If a cube as to be put on another cube, do we have to select the top face of the cube or the cube itself?
9411.4 In reply to 9411.3
Hi moujiik, maybe it should use a picked point for the target level instead of doing an object selection for it? Then you could use object snaps to snap to whatever spot you want.
9411.5 In reply to 9411.3
Hi moujiik, here's a version that works by picking a target point for the z level. Does this do what you need?
9411.6 In reply to 9411.5
It's just perfect
Very much thanks
Moujiik
Does this function make something different than the Native Move ?
9411.8 In reply to 9411.7
Hi Pilou, the script move the object only on z axis
Size: 233.4 KB, Downloaded: 66 times, Dimensions: 900x648px
9411.9 In reply to 9411.8
Not more powerful with Move + Helpers Lines ?
9411.10 In reply to 9411.9
@Pilou - yes it is possible to use Move + Construction lines to do this type of task currently. This is just a convenient way to do it with fewer steps if you need to do it often.
@moujiik - in the future when I get a chance to do some drawing improvements in MoI I'd like to incorporate some stuff regarding z level in the regular UI. Stuff like show the current selection's z level and maybe set a z level for drawing.
9411.11 In reply to 9411.10
Effectively it's a little more practical! :)
There was not yet something for snap to the nearest ?
Else Line / Line without scaling can make also some miraculous things! ;)
EDITED: 27 Jun 2019 by PILOU
9411.12 In reply to 9411.11
Could you please describe this a little more?
9411.13 In reply to 9411.12
Maybe something like that (not vital) ;)
A sort of collision...like your last one but in any direction or to the nearest...
9411.14 In reply to 9411.13
Hi Pilou, sorry no there isn't anything set up for that currently.
9411.15 In reply to 9411.14
No problem !:)
9411.16
Hi Michael, and Pilou. The script has already save me a lot of time. With a very intricate project, where some objects are deeply hidden and there are a lot of snapping points to chose from, it's very convenient to chose a reference Z point.
I often come up with lines that don't join because of different z level. It happens when drawing from top view, and flatten the whole thing often brings the curve to an unwanted z level. Then the script is usefull to bring the curve to the place we want to make an extrusion.
So, some stuff regarding z level like you describe will probably be a nice adition to the UI.
This being said, the UI is already extremely friendly, and a joy to use. Even with hours of continuous work.
Moujiik
Show messages: All  1  2-16
