label mapping
All  1-8  9-11
9410.9 In reply to 9410.8
Hi suman, what are you going to be doing with the model, are you making a rendering with it?
It may be better to apply the label as a texture map in a rendering program rather than trying to model a thin paper thing like that in CAD.
If you did want to model it using Flow note that the label does not actually adhere 100% completely to the bottle in this area here:
So probably the first step would be to prepare a second revolve that does have the shape that the label should adhere to, meaning it would not have the inward jump and maybe have a little bulge for the wire.
Something maybe like this as the profile for the revolve:
Then you're going to use that as the target for the revolve not the original bottle itself.
Maybe some projected 2D curves onto that might be easier than Flow.
9410.10 In reply to 9410.9
Hi Michael
I use this technique all time :
revolve shape
trim diecut
EDITED: 9 May 2020 by FINEMA
9410.11
You guys are great.
thank you very much for your help.
Show messages: All  1-8  9-11
