label mapping
9410.1
hello together
is it possible to put such a label around the neck of the bottle in moi?
if yes, which methods are these?
many thanks and summer greetings
Size: 14.1 KB, Downloaded: 29 times, Dimensions: 246x210px
Size: 55.6 KB, Downloaded: 40 times, Dimensions: 800x800px
Size: 2.4 MB, Downloaded: 69 times, Dimensions: 3507x2480px
9410.2
Hi suman,
You could try using Transform - Deform - Flow.
9410.3 In reply to 9410.2
Thanks for your help.
it still has a crease at the bottle neck.
and the etiquette runs over the middle of the bottle. so almost all around.
and that is my problem.
i tried flow but i don't see the solution and i don't think i understand the logic of the flow function very well.
Or this technic but with a cylinder! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=8745.1
EDITED: 27 Jun 2019 by PILOU
9410.5 In reply to 9410.4
Hi Pilou
Your Link go to the Forum Mainpage.
9410.6 In reply to 9410.5
Sorry! Repaired! Return above! :)
Unwrapcurve can help you in some cases for know how long is a curve!
http://moi3d.com/forum/index.php?webtag=MOI&msg=5136.1
9410.7 In reply to 9410.3
Hi suman,
Can you please post the .3dm model file with the objects that you were using?
9410.8 In reply to 9410.7
Hi Michael
Here is the Model:
9410.9 In reply to 9410.8
Hi suman, what are you going to be doing with the model, are you making a rendering with it?
It may be better to apply the label as a texture map in a rendering program rather than trying to model a thin paper thing like that in CAD.
If you did want to model it using Flow note that the label does not actually adhere 100% completely to the bottle in this area here:
So probably the first step would be to prepare a second revolve that does have the shape that the label should adhere to, meaning it would not have the inward jump and maybe have a little bulge for the wire.
Something maybe like this as the profile for the revolve:
Then you're going to use that as the target for the revolve not the original bottle itself.
Maybe some projected 2D curves onto that might be easier than Flow.
9410.10 In reply to 9410.9
Hi Michael
I use this technique all time :
revolve shape
trim diecut
EDITED: 9 May 2020 by FINEMA
9410.11
You guys are great.
thank you very much for your help.
