Marco's UI works with the Beta V4?
 1-17  18-30
Here the English version for the V 4 Beta of the Special UI by Marco! (Cmorph works fine also for me :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/marco_v4_eng.zip
If you don't want replace your Folder commands just copy past new files from this one!
Same for EnglishStrings.txt just copy lines 1472 to the end of it!
goto the original (made for the V 3) if you want some more detailed infos! http://moi3d.com/forum/index.php?webtag=MOI&msg=7862.1
Maybe Cmorph & MultiIso have no titles image for any reason but are working! :)
If you "degrade "_cmorph" in "cmorph" you must change it ALSO inside commands FOLDER !
All that is a little headache between French and English versions! :)
EDITED: 25 Jun 2019 by PILOU
9406.19 In reply to 9406.18
T-H-A-N-K
Y-O-U
V-E-R-Y-
M-U-C-H
PILOU!!!
I hope to find some spare time soon to try the new revamped scripts with my Moi V4.
A long time ago I've also written another BIG and (imho) very very powerful and useful plug-in for the Mo's UI.
Something that I called "Command Finder".
A tool that can speed up the standard workflow many times.
But it's rather complex the code that I've written, not elegant at all, no...but complex :)
But I don't know where the hell I've stored my original source code.
I I find it and you want to devote some of your precious time to it to make it work with V4, it WOULD BE AWESOME!!!
Thanks again for letting my old script working with V4.
9406.20 In reply to 9406.19
It's more Michael who makes things possible because I don't want put the nose in the code! :)
9406.21 In reply to 9406.20
T-H-A-N-K
Y-O-U
V-E-R-Y-
M-U-C-H
ALSO TO MICHAEL!
of course...
9406.22 In reply to 9406.21
Updated Marco's ScriptGallery for Moi-V4 Beta 10-10-2019. English version.
Note: Added Fatlines.png icon to zip file 10/13/2019
- Updated EnglishStrings.txt to fix cMorph and MultiIso icon text.
- Updated EnglishStrings.txt to fix missing Dims. Third time is a charm!
Wayne
EDITED: 9 Jun 2020 by WAYNEHILL5202
9406.23
Awesome! thanks :)
Works perfectly fine. If I'm not mistaken Fatlines icon is missing.
Edit: It's not missing. Just noticed...it's named Epaisseur.png
EDITED: 13 Oct 2019 by STARGAZER
Size: 13.3 KB, Downloaded: 25 times, Dimensions: 128x128px
9406.24 In reply to 9406.22
THANK YOU VERY MUCH FOR THE EFFORT :)
Much much appreciated.
9406.25 In reply to 9406.23
Maybe because I have mixed with my French version! :)
9406.26 In reply to 9406.25
Updated file with Fatlines.png icon. Yes, I started with Pilou's Eng/French version. ;)
Wayne
9406.27
Also another minor thing...
The text under those icons does not show up because their text in EnglishString.txt and ScriptGallery.htm doesn't match.
Thanks again :)
9406.28 In reply to 9406.27
Thank you Stargazer. I missed that. The EnglishStrings.txt is updated to include _cMorph and _MultiIso curve Icon Text.
9406.29 In reply to 9406.28
Hi WayneHill:
Just got your updates installed, and the Scripts Gallery is working, BUT:
Warning, your last English text strings does NOT have Dimensions, so it must be for the just expired MoI beta (?). My English strings is much larger that the update above.
It is very confusing to install with all of the old and new instructions, and names hidden in zip files...
I'll have to re-install again for the next Beta.../ and for Final version 4...
FatLines is now working :-)
I need a version with all of the "extra" commands with a _prefix, with the extra commands located in MoI AppData...
EDITED: 13 Oct 2019 by BEMFARMER
9406.30 In reply to 9406.29
Opps, reloaded old file instead of new edited file. Updated a third time... :)
A new version with extra commands? I am studying the Moi appdata area for another method of adding custom icon and scripts without altering the install files.
Wayne
EDITED: 13 Oct 2019 by WAYNEHILL5202
Show messages:  1-17  18-30
