Render Moi object online! free
 1-5  6-24
9400.6 In reply to 9400.4
@ Corchet : Des noms, des noms!
Il vaut mieux prévenir que guérir!
@ Finema : but no visible on a sphere so what is the default ? (see my example above)
(maybe not welded at the export ? )
EDITED: 11 Jun 2020 by PILOU
9400.7 In reply to 9400.6
comment exportes tu de MoI pour que ce ne soit pas facété ?
merci
I tested with .obj files and .iges.
I dont see hard facetted render.
When I export, I usually have many faces. Here, more than 14000.
Very fast render. Here about 2 seconds.
J'ai testé avec du .obj sortant de MOI3D et IGES.
Les facettes n’apparaissent pas.
Il faut dire que le nombre de facettes est important sur mes modèles lorsque je les exporte.
Ici 14000 triangles.
C'est assez impressionnant au niveau de la vitesse du rendu... 2 secondes ici.
My objects have 6 000 faces and welded...by default...no special regulates
9400.10 In reply to 9400.9
But you test online or standalone
On mac i can't download the standalone and with the web version here what I see when i open Light tracer Render
EDITED: 26 Jun 2020 by FINEMA
9400.11 In reply to 9400.10
Have you seen if your Graphic card is compatible
"Light Tracer can run probably on any GPU produced after 2013 (please download the latest drivers!)."
9400.12 In reply to 9400.11
Thanks Pilou
my graphic card is : AMD Radeon R9 M395X 4 Go graphismes on iMac (Retina 5K, 27 pouces, fin 2015)
but it's not a matter because i use keyshot 9 for professionnal renders and the great free Blender for for speed render with EEVEE
9400.13 In reply to 9400.12
So maybe try the Discord Light Tracer!
https://discord.com/invite/7gAsv9q
New version! 1.6.5
9400.15 In reply to 9400.14
giving it a try now it seems really slow and did not import all of the formats i thought it could...anyway lets see, maybe it might
be done 'later' ;o)
What is the best 'not too expensive' renderer for moi3d users in your opinion Pilou?
9400.16 In reply to 9400.15
My 2 favorites are the free Real Time Render SimLab Composer Lite ! (max 1980*1040 )
https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx?utm_source=free_tools
Super easy : accepts quasi all 3D formats (except 3DM from Moi so take OBJ from Moi)
So you can import and mix many different things!
And the Free TwinMotion 2019 - 2020 without any limitations - terrific simplicity and such vegetations wind, snow, ocean animation's camera etc...
( free if you had downloaded the 2019 by Epic Games) who is even more easy if possible!
EDITED: 31 Aug 2020 by PILOU
Another one! For the Moi SPK exported models ! ;)
A free version is existing!
https://www.coohom.com/
EDITED: 1 Sep 2020 by PILOU
No render online...
Bella Render Free in 1280*720 Integrated in SketchUp, Rhino, Maya or in Standalone
https://bellarender.com/
For the moment for the OBJ import you have to put all the files on the same path level! Mesh, Mtl, texture... etc
9400.20 In reply to 9400.18
I've never heard of this render farm before, so far, I've been using https://rebusfarm.net for the longest time... which is why I was going to recommend it here, if you get the chance you should check it out too, they really have one of the best render farms I've seen, really fast and really affordable.
Can maybe useful! ;)
Not sure it is in the free Web version... (verified...it's not! :(
EDITED: 21 Nov 2022 by PILOU
Not exactly a render but...
CGDream
https://cgdream.ai/
Free 20 images / Day, 1024 x 1024
252 Filters (5 maxi), 5 enhances / Day
import 3D GLB, FBX (so moi3D!!!
Filter Sc-fi : 1.00
Vizcom same prompt, (very complex colored transparent engine)
6 renders engines 100%, same start image (CGD), last 4 Refine, 90,50,3,10 %
But Vizcom can make the same : import a 3D object directly inside and render it!
Vizcom free + import volume 3D OBJ (from Moi3D) :)
A prompt + an image as style!
9400.24
Thinking of getting light tracer.
I use blender but light tracer seems faster....when you are a one man show ...every minute counts :D
Show messages:  1-5  6-24
